Pilot Bearing HELP!
Old Jan 29, 2008 | 05:04 PM
Corvette Don's Avatar
Corvette Don
Default Pilot Bearing HELP!
Any of you guys know which way the pilot bearing goes into the crankshaft? There are 2 ways it can go in
Old Jan 29, 2008 | 05:12 PM
mikey's Avatar
mikey
I believe (from recollection) that the more rounded side (leading into center hole) faces away from the motor (towards you).
Somebody else should confirm or deny..
Old Jan 29, 2008 | 05:29 PM
vettenuts's Avatar
vettenuts
The taper faces aft and the open bearing faces forward.
Old Jan 29, 2008 | 05:36 PM
Corvette Don
That still does not help me too much Anyone else, I am putting this stuff in now and this is holding me up
Old Jan 29, 2008 | 05:47 PM
Corvette Don
Which pic should the bearing face toward me (rear) when installed?
Corvette Don
Thanks for the help guys!!!!!
Old Jan 29, 2008 | 09:19 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The first one.
Old Jan 29, 2008 | 11:01 PM
chuckster's Avatar
chuckster
Not to be a smartass.. but conventional wisdom would be able to tell you simply by looking at it.. Tapered side faces you..
Its a "Pilot" Bearing. Meaning it Guides.... The Tapered face would be 100 times easier to guide a shaft into it than the other side...
on doing your own install.. I wish I had the cajones to tackle a job like that..
To Pilot Bearing HELP!
