Line lock
Old Dec 2, 2001 | 06:39 PM
robiferretti's Avatar
robiferretti
Default Line lock
How hard is it to install a line lock? What parts do i need to install it? and how much does it cost?
Thanks in advance
Old Dec 2, 2001 | 06:51 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Line lock (robiferretti)
Easy as eating Pie!
Previous post: http://forums.corvetteforum.com/zerothread?id=185958
http://forums.corvetteforum.com/zerothread?id=161296
http://forums.corvetteforum.com/zerothread?id=170198
http://forums.corvetteforum.com/zerothread?id=158220
http://forums.corvetteforum.com/zerothread?id=141421
http://forums.corvetteforum.com/zerothread?id=93581
[Modified by wallstAL, 3:25 PM 12/2/2001]
Old Dec 2, 2001 | 11:09 PM
robiferretti
Default Re: Line lock (wallstAL)
Thanks a lot i appreciate it...winter project...may take you guys an hour its going to take me all winter :yesnod:
Old Dec 2, 2001 | 11:20 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
LGM is selling the Hurst Roll control with a C5 installation kit. The install of line locks aren't usually that difficult. It involves the mounting of the line lock solenoid, running a relay and the switchs, and intercepting the front brake lines off of the ABS module. Afterwards as with any time you open the brake lines you will need to bleed the brakes.
I have installed the Hurst Roll control in the past using my own wiring and bending/flaring my own brake lines - not too bad about a 2-3 hour job total. The installation kits will make it easier though.
http://www.lgmotorsports.com/catalog...mission&car=c5
To Line lock
