cam selection?
Old Feb 11, 2008 | 04:40 PM
dawiz's Avatar
dawiz
Default cam selection?
hey guys im looing for some suggestions on a cam. currently the car is a bone stock 99frc with 59k miles.
i have ordered american racing long tubes 1 7/8 and have a ti exhaust here to be installed with the headers.
i will most likely do an ls6 intake with the cam install.
my goal is good drivability with great sound. im not planning to take this car all out. i want decent power but drivability is going to be important.
i am considering one of england greens cam packages.
thanks!
Old Feb 11, 2008 | 04:49 PM
HD2HVETTE's Avatar
HD2HVETTE
I Just went with a GM stage 2 cam, 227/239 .551 lift 108 LSA along with Z06 heads and LS6 intake-because the cam will work with Z06 springs and the light-weight valves. Will be tuned the 22d. Figure I saved by not buying springs/retainers/kit so put it towards the price of the heads. Should have good driveability with a nice sound at idle (I like a choppy idle!) I'll let you know how it tunes out and drives.
Old Feb 11, 2008 | 05:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I'll suggest Stephen's "monster" cam as a good moderate-to-slightly aggressive cam for a typical street car.
Should have real good manners/drivability, yet still sound pretty tough.
Old Feb 12, 2008 | 01:40 PM
dawiz's Avatar
dawiz
anyone else?
Old Feb 12, 2008 | 02:49 PM
AU N EGL's Avatar
AU N EGL
Comp Cam 224/224 .581/.581 112
EG does some very good work.
Old Feb 12, 2008 | 06:15 PM
kingsey's Avatar
kingsey
IM really leaning towards vengeance racing vrx3 cam.
Old Feb 12, 2008 | 06:25 PM
Pro Street's Avatar
Pro Street
I have the 224/224 581/581 114LSA from Texas Speed with stock heads and TQ.Also have 3:15 gear and it seems so to work great.I have tuned it myself with HPTuners.
Old Feb 12, 2008 | 08:53 PM
Brad@RevXtremeAutoSports's Avatar
Have you spoken to EG??????
If he is going to sell you the package and do the work (?????) why not talk to him first, then get other opinions if you feel you need to.
(Unless this is what you have already done but didn't say )
Seriously though, Stephen will guide you in the right direction.
Good Luck
Old Feb 12, 2008 | 09:19 PM
dawiz's Avatar
dawiz
yes i have talked to stephen and he and i are working on coming up with a plan. right now im looking for an ls6 intake. i hope to find one soon cause im going on vacation in two weeks and want to drop the car off before i go away.
Old Feb 13, 2008 | 08:25 AM
LDB C5's Avatar
LDB C5
The suggestions that I would make are make sure you understand what you want from your car. Choose a cam that will get you there, and maybe go one step larger. That will save you the agrivation and expense if you are paying someone else to do the work, of going bigger in the short term. I have the Vengeance VRX5 but I have other mods as well.
Good Luck
Old Feb 13, 2008 | 09:41 AM
kilrb's Avatar
kilrb
That's what I have in my 99 FRC (which just happens to have about the same mileage as yours). With 5.3L heads, L6 intake, and longtubes, I'm putting down a conservative 410whp, and boy is it fun. Lots of low-end torque, and plenty of power. If you are **** about idle and driveability, you may not want to go much bigger. Here's my writeup on my impressions, an idle clip through longtubes/Z06 Ti catback (we have basically the same setup), and my dyno graph.
http://forums.corvetteforum.com/show....php?t=1685920
Old Feb 13, 2008 | 10:14 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I have a 224/228 581 588 114 with TFS heads and I put down 423 RWHP before the other goodies.
It is a reasonable cam from Comp Cams and has good idle qaulity and great HP and TQ!
Thanks,Matt
To cam selection?
