C5 Lift Plate
Old Feb 15, 2008 | 01:10 AM
LIGHTNING's Avatar
LIGHTNING
Default C5 Lift Plate
anyone have one of these? attaches to floor jack to lift front or rear of C5. wondering if it's better than using a piece of wood.
part #654-008 in MidAmerica Cat. www.mamotorworks.com
Old Feb 15, 2008 | 10:44 PM
jedblanks's Avatar
jedblanks
Doesn't seem like this is necessary.
You can easily lift the front with the crossmember in front of the transfers front leaf spring and easily lift the rear just behind the rear transverse leaf spring.
That plate would make it harder/impossible to get the floor jack under the car. Its already hard enough.
Old Feb 15, 2008 | 11:52 PM
Oldvetter's Avatar
Oldvetter
I use a treated (harder) 2X6 inch piece of wood. The advantage of the metal piece is that it has "edges" that would align it.
Old Feb 16, 2008 | 05:36 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Not a bad item to have.
I use to use a wood block, then I got a (4) post lift. If I did not have lift I would get one for myself.
Old Feb 16, 2008 | 07:58 AM
vettenuts's Avatar
vettenuts
I use a 5 lb barbell weight that I glued a sheet of rubber to. The weight spreads the load to the vertical section of the cross member. Its about the only time I lift anymore
Old Feb 16, 2008 | 10:05 AM
dndrsn's Avatar
dndrsn
"JACKING-BOARD"
Old Feb 16, 2008 | 11:00 AM
bighank's Avatar
bighank
Default Neato and the price is right too
Originally Posted by dndrsn
BIGHANK
Old Feb 16, 2008 | 03:14 PM
Oldvetter's Avatar
Oldvetter
GREAT IDEA ! I will do those modifications to my 2X6 board !
Old Feb 16, 2008 | 06:06 PM
rws.1's Avatar
rws.1
I use a 2x6
To C5 Lift Plate
