Radiator shroud replacement?
Old Dec 4, 2001 | 12:58 PM
C5Noir's Avatar
C5Noir
Default Radiator shroud replacement?
For those that have done it, did that sponge weather stripping falling out when you replaced yours? If so, how did you replace it? Thanks.
Old Dec 4, 2001 | 01:08 PM
C5Cemo's Avatar
C5Cemo
Default Re: Radiator shroud replacement? (C5Noir)
Yes...that stuff is barely on there, isn't it?
The first 10 times I added 3M double-sided tape to it and cleaned the heat exchanger with alcohol before sticking it back together. What a PITA! I have seen the same type of foam material in strips for sale at Home Depot, Lowes etc. if you want new ones.
Now I don't even use those strips anymore. I have'nt notice the car run any hotter either.
Old Dec 4, 2001 | 01:14 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
C5Noir,
The foam seals began to loosen and move out of place on my 1999 Coupe soon after I purchased the car new. I used black silicone sealer to "glue" the foam seals in place.
The quality of the part is very poor - a classic example of cheap materials used in production.
1999 White C5 Coupe
Old Dec 4, 2001 | 01:39 PM
carpe dm's Avatar
carpe dm
I didn't have any on mine....... It must have blown ( :jester ) out, or been discontinued. I don't believe it would make much difference one way or the other. :rolleyes:
To Radiator shroud replacement?
