Need help understanding codes ? ? ?
Old Feb 24, 2008 | 02:38 PM
slypnslyd's Avatar
slypnslyd
Default Need help understanding codes ? ? ?
got a couple of codes dont understand
what they mean can someone help ????? P L E A S E !!!!!!!
codes-
b2587-column lock/unlock drive a
b2723-pass-key detection cir
u1064-lost comms with bcm
c2100-left front tpm sensor malfunction
thanx ,
Angelo
Old Feb 24, 2008 | 02:39 PM
racetchr's Avatar
racetchr
If you are getting these codes and arent having the probs, you might try disconnecting the battery for about 15min and see if they reset.
Old Feb 24, 2008 | 03:00 PM
slypnslyd's Avatar
slypnslyd
Thanks Racetchr
i reset them allready just wanted to make sure it was nothing to worrie about ...........only have the car for a week so everything is new to me
thanxs again
Angelo
Old Apr 10, 2008 | 05:38 PM
lenbal's Avatar
lenbal
Default U1064 Loss of Communication with BCM
hi
I get U1064 Loss of Communication with BCM
and get check engine light - what does BCM stand for
I can clear it but keeps coming back - have an a4 01 dynamaxx long tubes and vararam, dynoed about a yr ago- gone thru 3 sets of sensors - that what the dealer has found wrong - warranty company getting upset --
codes appeared again today - been about 4 months since last set of sensors -now that i think of it happens about every 4 months
any ideas, help
Thx Len
Old Apr 10, 2008 | 05:54 PM
Humy's Avatar
Humy
BCM = brake control module
that is all I can offer, sorry
Old Apr 10, 2008 | 06:01 PM
lenbal's Avatar
lenbal
Hi and thanks found it but now what the heck does it mean
Body Control Module (BCM)
Old Apr 10, 2008 | 07:27 PM
BlackZ06's Avatar
BlackZ06
INCORRECT .... The brake computer is referred to as either the EBCM (Electronic Brake Control Module) or EBTCM (Electronic Brake Traction Control Module)
The Body Control Module is located under the carpet in the passenger footwell (to the left of the fuses).
The BCM controls the SECURITY system (both the Content Theft Deterrent and the Vehicle Theft Deterrent), vehicle lighting, and coordinates locking/unlocking the car when the RFA picks up the key fob signals.
A U1064 does not set the CHECK ENGINE light. You have a Pxxxx code set in your PCM, check again and post the code(s).
The Uxxxx codes are set by a computer when it decides it is unable to communicate with another computer on the network. They can usually be ignored unless there are other symptoms indicating a problem with the serial data network.
Old Apr 11, 2008 | 05:50 PM
lenbal's Avatar
lenbal
thx will wait til it happens again - inthe past they occur a lot once they start
Had an SCM - code today went to fast to write number is there a way to stop them so you can write down
Len
Old Apr 11, 2008 | 10:33 PM
BlackZ06's Avatar
BlackZ06
Len
When the display has finished flashing through the codes it will stop and say something like "Manual Diagnostics". Press the OPTION button and the DIC will scroll through each computer in the car. To see a previous computer press TRIP.
To see an individual code press GAGE. If a computer has more than one DTC set each time you press GAGE it will show the next one .... FUEL will reverse and let you see the previous code.
If you want to delete a code, press and HOLD the RESET button.
The E/M button will take you out of the DTC Display and return the DIC to "normal" operation.
Old Apr 11, 2008 | 11:10 PM
mrgil's Avatar
mrgil
Burnout
Default Codes
If you are using a window Valet, the BCM does not like it because it interferes with the communication. Pull the window valet and clear the codes, if the U1064 doesn't reset I'm right. if it does set U1064 again I have no idea what is causing it.
mrgil
Old Apr 11, 2008 | 11:13 PM
mrgil's Avatar
mrgil
Burnout
Default headers
hi
any ideas, help
Thx Len
I have dynamaxx Longtubes and was getting O2 Codes, traced it to a faulty O2 sensor and its been fine ever since.
My headers are ceramic coated inside and out to keep as much heat inside them for O2 sensors as possible. need 600F for the rears to lite up.
mrgil
To Need help understanding codes ? ? ?
