Timing chain question
Old Feb 24, 2008 | 07:58 PM
Venomized03's Avatar
Venomized03
Default Timing chain question
I have a 01 Z06 with the LS6 obviously. I just recently purchased a MS4 cam kit and I was wondering if you guys think I need to buy a new timing chain. If so, which one? I think I used the LS2 timing chain kit on my old SS but wasnt sure if I need one in this car. All opinions would be great.
THANKS
Old Feb 24, 2008 | 08:04 PM
vettenuts's Avatar
vettenuts
Personally, I would change it while you are in there. The pre-LS2 chains weren't that strong and with some mileage you likely have some stretch on it.
Old Feb 24, 2008 | 08:16 PM
RIDE3311's Avatar
RIDE3311
I would definitely pay the extra money for a double roller timing chain like Rollmaster or something. It never hurts to have that extra safety.
Harshil
Old Feb 24, 2008 | 09:47 PM
Russ K's Avatar
Russ K
An LS2 chain is used on a lot of high rpm engines with out failures. A double roller usually requires the oil pump to be shimmed away from the block, clearancing of the back side of the oil pump and the timing cover.
Russ Kemp
Old Feb 24, 2008 | 09:51 PM
black98c5's Avatar
black98c5
LS2 timing chain is what I'm running.
Old Feb 24, 2008 | 09:55 PM
Corvette Don's Avatar
Corvette Don
Old Feb 25, 2008 | 06:13 AM
vettenuts's Avatar
vettenuts
I think the bigger question is whether you plan to degree the cam (recommended). If so, then the sprockets may need to be changed as well.
Old Feb 25, 2008 | 09:22 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Another vote for the LS2 chain.
Old Feb 25, 2008 | 07:21 PM
spiral04's Avatar
spiral04
Old Feb 25, 2008 | 07:29 PM
AMRAAM's Avatar
AMRAAM
I have the LS2 chain as well, however, I havent ran the engine since I put it on.
Old Feb 25, 2008 | 08:16 PM
AMRAAM's Avatar
AMRAAM
this pic doesn't show it well, but there is a very noticeable difference in the beefiness of the LS2 chain compared to the stock LS1 chain
Old Feb 25, 2008 | 08:27 PM
vettenuts's Avatar
vettenuts
Here's another view. I can't take credit for this photo as someone else posted it some time back and I saved it, but it does show the difference. LS2 on the bottom.
Old Feb 25, 2008 | 08:58 PM
Venomized03
Wow awesome guys, I really appreciate the info.
Looks like I am going with the LS2. I will order it tomorrow
To Timing chain question
