Valve spring guidance
Old Feb 25, 2008 | 12:27 PM
tiki240's Avatar
tiki240
Default Valve spring guidance
I just bought a G5X2 cam, and I was wondering if the following springs will be sufficient for the application. Im running a stock 5.7L LS1
here are the specs on the cam
232/240 .595/.608 112LSA
here are the specs on the springs in question
Chrome Silicon Dual w/ damper
135 lbs. @ 1.875"
395 lbs. @ 1.225"
400 lbs. rate per inch....set of 16 in package
coil bind 1.160"
Maximum Lift .650"
outer 1.530" O.D. inner 1.005" O.D.
Old Feb 25, 2008 | 01:40 PM
tiki240's Avatar
tiki240
any cam gurus online middle of the day?
Old Feb 25, 2008 | 01:42 PM
racetchr's Avatar
racetchr
I have run this particular cam and think you have more than enough spring with this cam.
Old Feb 25, 2008 | 04:59 PM
vettenuts's Avatar
vettenuts
Do those come with retainers? Here is my concern. You are going to set up at 165 lbs on the seat with a 1.800" installed height. If they install at 1.875, then the retainer will sit high on the valve stem and you could have contact issues with the rocker. What is the diameter of the spring? Whose springs are these?
PS: PAC just introduced a dynamite dual for the LSx head.
Old Feb 25, 2008 | 05:17 PM
tiki240's Avatar
tiki240
PMed you both :-D
Old Feb 25, 2008 | 05:55 PM
vettenuts's Avatar
vettenuts
OD is way to big for stock heads without machining. You need to get an LS1 designed valve spring.
Old Feb 25, 2008 | 06:08 PM
vettenuts's Avatar
vettenuts
Contact LG, they will likely recommend the Comp 921's. Crane 833's will work as well and the set is a little less money.
Old Feb 25, 2008 | 06:45 PM
chriswtx's Avatar
chriswtx
Those wont fit a stock head, to big OD wise..You need a 1.3" OD spring. Patriot gold springs(Patriot heads) are perfect, come with titanium retainers, locks, and new valve seals for $255...
Old Feb 25, 2008 | 08:08 PM
tiki240's Avatar
tiki240
thanks guys! I really appreciate it
To Valve spring guidance
