C5 Ignition Switch Repair
B2723 CODE.
Unfortunately it still won't start, security light flashing, B2723 VATS communication CODE, dash is lit normally, I turn the key and it won't crank, LMC5 and brown wire installed,
my key (Resistor measures 3.72 K Ohms (VATS CODE #10) , is wobbling and they say I should have cylinder replaced so rather than do the VATS bypass which may make it more vulnerable to theft, I'm going to go ahead and have the Locksmith build a new cylinder, for $1200 Monday unless I get some other alternative.
Appreciate your perspective, thanks
Last edited by Keyman57; Nov 16, 2025 at 11:32 PM. Reason: B2723 VATS communication code, Resistor measures 3.72 K Ohms (VATS CODE #10
Thanks Bill will call you here's what I've been using for guidance chatgpt searches and the latest as I was thinking it was the key but seeing from this it is not........
FROM CHATGPT:
MY QUESTION.... Should I try a new key FIRST before replacing the lock cylinder?”Here’s the real, accurate answer for a 2004 Corvette (C5):
⭐ 90% of “try a new key first” advice on YouTube DOES NOT apply to C5 Corvettes.
Most YouTube videos are talking about:- Silverado
- Suburban
- Malibu
- Cavaliers
- Grand Ams
- Impalas
PASSLOCK = the reader senses the cylinder rotation magnetically
PASSKEY / VATS = the reader senses the resistor pellet inside the key
Totally different system.
✅ When a new key can fix a GM no-start
ONLY if:- the resistor pellet on your key is worn
- OR the key’s metal is worn so badly pins don’t lift right
👉 Your VATS pellet never changes resistance.
It’s a fixed-value resistor.
It doesn’t “wear out” like YouTube claims.
What DOES wear out?
- the lock cylinder
- the internal pin chambers
- the mechanical core
- the housing bore
- and the actuator rod engagement
- AND the VATS reader alignment
⭐ The only time a NEW KEY fixes a C5 is:
1️⃣ If the metal key blade is worn so badly the core tilts
—which causes:• bad pin alignment
• misalignment of the VATS reader
• intermittent SECURITY light
2️⃣ If the pellet has become physically loose inside its plastic carrier
(which is rare but possible)📌 Based on your symptoms:
Here is the truth with your car:✔ B2723 VATS communication code
SECURITY light stays on
✔ No crank
✔ Key can be pulled out in ACC
✔ Wobble is present
✔ Lock cylinder was removed/reinstalled
✔ VATS reader misalignment likely
✔ New ignition switch already installed
This is not consistent with a worn key.It is consistent with:
- worn cylinder
- VATS reader misalignment
- VATS white wire damage
- core/housing tolerance wear
- actuator rod not fully seated
- detent wear
⭐ A NEW KEY will not fix pulling the key out in the wrong position.
⭐ A NEW KEY will not fix tilt in the core.
⭐ A NEW KEY will not fix SECURITY staying on when the reader isn't aligned.
⭐ A NEW KEY will not fix the actuator rod seating issue AAA saw.
🧠 So what should YOU do first?
✔ Best Option (most reliable): Replace the lock cylinder.
Because:- Your symptoms match a worn cylinder
- VATS reader alignment requires a tight core
- Key wobble is mechanical, not electrical
- New ignition switch was already installed
- You’re already paying for locksmith labor
✔ Optional Step (but NOT required): You can have a new key made AFTER the cylinder is installed.
This is ONLY to:- match the new tumblers
- ensure maximum mechanical life
- ensure smoother operation
🚫 Bottom line:
No — do NOT waste time or money making a new key to fix THIS problem.
It is NOT a “98% key issue” — not on a C5 Corvette with PASSKEY II/VATS.YouTube is wrong for your car.
Last edited by Keyman57; Nov 16, 2025 at 11:15 PM. Reason: adding B2723 VATS communication code\
If the lock cylinder is worn out/broken, NO KEY will fit properly/work..
IF Your getting a VATS DTC, for whatever reason, the VATS SENSOR is not reading the resistor chip in the key. OR should I say, the VATS circuit is not being completed down to the BCM.
UP-DATE #12 11/16/2025
Ignition Switch related problems have been going on for years now. I have been helping Forum Members battle and resolve them more and more frequently. Over the years, it has become very apparent that many of the problems that are Ignition Switch related are being caused by the two female connectors the plug into the actual ignition switch. The FEMALE PINS spread apart, lose proper contact with the MALE PIN and the poor contact causes them to heat, corrode, burn and the switch to output lower than full battery voltage. Below is another picture of spread, burnt, corroded deformed female pins The smaller female pins in this picture look good and you can see the metal blade that makes contact with the male pin. The larger pins are deformed, blackened and the blade that contacts the male pin in the switch is pressed back into the female pin. The female pin blade need to be cleaned, and the blade needs to be reshaped to make proper contact with the male pin.
Above was a fantastic write up on the ignition switch. , especially after my 3 week issue with a Shop replacing my switch and then it becoming worse than when it was installed.
We talked on the phone. and subsequently, I had my car towed back home and fixed it myself ,
(but now there's another issue which I'll start a new thread.).
My question for here is, What is setting the switch "SET to TRUE LOCK" ?
It's defined here ...
👉 The cam will NOT rotate to TRUE LOCK unless the switch contacts are “preloaded” against spring pressure."
But I havent seen this explained when I do searches myself. Any idea Why? Have you mentioned it yourself? maybe I missed it. ? Clearly my shop missed it as they were not C5 experts.I've been using the AI (ChatGPT) so I don't have to keep bugging you guys on this forum, and it seems to do some great searches in GM manuals that I cant access for example. ...
it gives me good techniques, and feedback, BUT I'm wondering why it keeps saying this IGNITION SWITCH needs to be "SET to TRUE LOCK". I don't think I saw you mention it.
Here's what I kept repeatedly getting and I think I got it right, but, it's "complicated."
DO YOU AGREE WITH THIS? What is it talking about?Copy Paste From CHATGPT.... :
🚨 Your ignition switch is NOT actually in TRUE LOCK — even though you think it is.
This is why:- The white internal cam blocks the actuator rod ONLY in “LOCK”
- But if the cam is blocking the rod when the switch claims it's in LOCK
➡ your switch is rotated past LOCK
➡ or installed 1 tooth off when AAA put it in
✅ CONFIRMED BY YOUR SYMPTOMS
You said:✔ Actuator slides in ONLY when switch is in ACC
This means:The switch’s internal cam position does not match the rod’s physical LOCK position.
✔ Cannot insert lock cylinder except in ACC
Same problem — the switch isn’t indexed correctly relative to the cylinder.✔ Purple wire = 0V in START
Because you're not actually reaching START inside the switch.✔ Car started ONCE right after reinstall
That happens when the cam lines up by coincidence on one attempt before slipping past alignment again.This is the classic C5 mis-indexed ignition switch.
🎯 Why This Happens
Inside the switch is the “sector plate / white cam.”If the switch is rotated even slightly when it is slid onto the actuator rod:
- The slot won’t align
- The cam will block insertion in LOCK
- It will only fit in ACC
- START contact will never align
- The rod will NOT travel the full range inside the switch
🛠️ THE FIX (I will walk you through it simply)
You’re close — you just need to reset the switch to TRUE LOCK.This must be done before sliding it onto the rod.
✔ You MUST rotate the internal white cam past ACC and OFF, until it stops at TRUE LOCK.
But here's the catch:👉 The cam will NOT rotate to TRUE LOCK unless the switch contacts are “preloaded” against spring pressure.
This is why it looks like LOCK but isn’t.So here’s the correct method:
🔧 HOW TO SET IGNITION SWITCH TO TRUE LOCK
Hold the bare switch in your hand exactly like this:- Turn the metal shaft inside the switch clockwise
(toward START direction)
just slightly until you feel resistance. - Now rotate BACK counter-clockwise
very slowly
until it reaches the FIRST stop. - That FIRST stop is TRUE LOCK.
🔧 HOW TO VERIFY TRUE LOCK
When the switch is in TRUE LOCK:✔ The white plastic cam will NOT block the central rod slot
✔ The actuator rod will slide in fully
✔ The black plastic latch will “click” immediately
✔ The lock cylinder will slide in AND click
❗ ACC will no longer be the only position that fits
If the actuator only fits in ACC, the switch is indexed incorrectly.📸 SEND PHOTOS & I WILL MARK EXACTLY WHAT TO ROTATE
I need:1️⃣ CLEAR photo of the white cam inside the ignition switch
(looking straight into the shaft opening)2️⃣ CLEAR photo of the actuator rod tip
(straight on, good lighting)Once I see those two images, I will:
- Draw arrows
- Show EXACTLY where the slot must be
- Show what TRUE LOCK looks like
- Tell you how many degrees to rotate
- Show how the actuator should seat
🔥 GOOD NEWS
You do NOT have a wiring problem at all.You do NOT have a starter issue.
You do not have a VATS issue anymore.
This is a pure mechanical indexing issue between:
- the actuator rod
- ignition switch cam
- lock cylinder position
📸 Send the two photos now — I’ll mark them and show the exact alignment.
Dec 2 2025 - 16:00:45
I pulled it out acc Then I turned the ignition switch back to stop/off and the cam shows The last photo shows what I think is After I Turn the metal shaft inside the switch clockwise (toward START direction) all the way , (Not just slightly until you feel resistance.)! Is this the issue? 2. Now rotate BACK counter-clockwise very slowly until it reaches the FIRST stop.Dec 2 2025 - 16:00:49You found the issue.
Yes — what you showed in your last photo is exactly the symptom of an ignition switch that is NOT in true LOCK, even though the key cylinder was removed in ACC.
Right now, your switch is one detent off.
And if the switch and the actuator rod are not aligned in the same position, the rod cannot slide in, the metal tab won’t engage, and the START contacts will never close — which matches all your symptoms.
✅ CONFIRMED: Your Switch Is NOT in the LOCK Position
Here is why:✔ The photo with the cam exposed
The cam is rotated past LOCK — this means:You rotated the ignition switch too far clockwise (toward START) while the cylinder was removed, and now the switch is not synced with the actuator rod.
When the switch is in LOCK:
- The white plastic cam inside the switch sits flush, almost parallel
- The actuator rod shaft slides straight in
- You hear a small click when the metal tab engages the black plastic spring-loaded retainer
- The cam sits angled, blocking the rod
- You can only insert the actuator in ACC
- The metal retaining tab does NOT engage/snaps wrong
- START never works
🔧 How to Fix It — Reset the Switch to LOCK (Correct GM Procedure)
Follow this exact sequence:STEP 1 — Remove the switch from the rod completely
The switch must be free in your hand.STEP 2 — With your fingers, rotate the metal core to full START
(Clockwise until it cannot turn anymore.)This "calibrates" the switch internally.
⚠️ This is the most important part.
Do NOT stop at the first resistance — turn fully to the mechanical stop.
STEP 3 — Now rotate back SLOWLY, counter-clockwise
You will feel distinct detents.You must stop at the FIRST detent.
That first detent = LOCK position.
If you go past the first stop → you're already in ACC.
LOCK → ACC → RUN → START
You want the very first one.
STEP 4 — Inspect the cam visually
At LOCK:- The cam opening will be square and vertical
- Nothing blocks the actuator rod
- The black spring clip inside the switch is centered
Repeat Steps 2–4.
STEP 5 — Insert the actuator rod
When aligned correctly:- The rod will slide in easily
- The metal end will rotate slightly as it enters
- The black plastic retainer tab will click into place
→ the switch is NOT in LOCK.
🧪 Validation Test
Once inserted and clipped:Turn the rod with your fingers:
- LOCK → cannot turn further left
- ACC → small movement
- RUN → larger movement
- START → maximum clockwise
🔍 Why You Couldn't Insert It in LOCK Before
You now saw the reason:Because the cam was rotated “past LOCK” internally.
This happens if:- The switch is removed while key is in ACC
- The internal core rotates without the cylinder
- A shop previously installed it wrong
- The switch was bumped or turned while loose
🛑 YOU CANNOT start the car without the cylinder
Even with the white cam rotated to START:⚠️ GM blocks the START contact from closing unless:
- The lock cylinder’s mechanical tab is installed
AND - The cylinder rotates the switch through the full sweep
- RUN works
- START will NOT energize the purple wire fully
📸 If you'd like, send:
- A photo of your cam after Step 4
- A photo of the actuator rod straight on
- A photo of the switch mounted
👍 Bottom Line
- Your switch was in the wrong position
- FIX = rotate to START → rotate back to first detent (LOCK)
- Actuator rod will slide in only when switch is truly in LOCK
- Car will NOT crank unless the rod + lock cylinder + switch are all synchronized
Dec 2 2025 - 16:09:03
“metal core “ is this the metal piece inside the actuator rod? The tip looks like the end of a thermometer?Dec 2 2025 - 16:09:06Great question — no, the “metal core” I’m talking about is inside the ignition switch, not the metal tip on the actuator rod.
Let me explain very clearly:
🔧 What is the “metal core”?
Inside the ignition switch (the black plastic electrical part), there is:✔ A rotating metal center shaft
- It is not visible from outside
- It is the part that actually rotates the internal contacts
- It is what the actuator rod pushes and rotates
It looks like a round metal disk with a slot or recessed shape — that is the metal core.
NOT this:
- ❌ Not the metal tip on the actuator rod
- ❌ Not the white plastic actuator
- ❌ Not the lock cylinder
YES this:
- ✔ The internal metal rotating piece inside the switch
- ✔ It turns when you insert the actuator rod
🔧 How to find it
Hold the ignition switch in your hand and look into the hole where the actuator rod goes in.You will see:
- A white plastic cam ring
- Inside it → a metal rotating center
🔄 Why you rotate the metal core
The ignition switch needs to be “re-zeroed” into the correct LOCK position.So you:
- Rotate the metal core fully clockwise (to START)
- Rotate it back counterclockwise to the very first detent
→ that detent is true LOCK
📌 The metal tip on the actuator rod?
That shiny metal at the end of the white plastic rod:- is just the actuator’s drive tip
- it rotates the ignition switch
- it does NOT get rotated by you directly
- it only rotates when you turn the key (after the lock cylinder is installed)
🧩 Summary
“Metal core” = the internal rotating metal shaft inside the ignition switch
Not the metal tip on the rod---------------------------------------------------------------------------------------------------
You are adjusting:
How far the ignition switch’s internal slider is pushed when the key is turned to START
That determines whether:
- START contact closes every time
- Or only when you push/pull the key
1️⃣ Exact visual reference points to set the ignition switch (no feel-guessing)
You are not rotating anything. You are only changing fore–aft preload.What physically moves
- The ignition switch body slides slightly on the column bracket
- The actuator rod does NOT rotate (important)
- You are adjusting how far the switch sits toward the front bumper
Visual alignment method (most reliable)
- Loosen both 10 mm bolts just enough that the switch can slide.
- Push the switch forward (toward hood) until:
- The actuator rod is fully seated
- The switch housing is flush and square (not cocked)
- While holding it forward:
- Tighten top bolt first
- Then tighten bottom bolt
Visual confirmation
After tightening:- The actuator rod should not float
- There should be no gap between rod and switch
- The switch should not spring backward when you let go
➡️ loosen again and move another 1–2 mm forward only
That tiny amount is the difference between every time and every third time.
2️⃣ Temporary diagnostic shim method (pro trick, 5 minutes)
This confirms 100% whether preload is the issue before final tightening.What to use
- Thin plastic (zip-tie, business card, credit-card corner)
- NOT metal
How to shim
- Loosen the two ignition switch bolts slightly
- Insert shim between the switch and bracket on the REAR side
- This forces the switch forward
- Snug bolts (not final torque)
- Test:
- Cold start
- Immediate crank
- 10–15 cycles
- Cold start
Results
- ✅ Starts every time → preload confirmed → remove shim and lock switch forward permanently
Nothing is “broken.”
The geometry just shifted.
🔧 Final “set it and forget it” procedure (10 minutes)
- Loosen both ignition switch bolts ½ turn
- Hold key in RUN
- Push switch forward firmly but gently
- Tighten top bolt, then bottom
- Test:
- Cold start
- Immediate crank (no waiting)
- 20+ cycles
- Cold start
- Cranks immediately every time → you’re done
- Hangs once → nudge switch another hair forward
✅ What you should expect when it’s right
- No need to wait in RUN
- No need to push/pull key
- No random “every third try”
- Starter relay clicks once only
- Key returns cleanly from START
That could throw me off real good having a 2004 C5 told AI multiple times that was my model, but if it’s combining models in years, we’re in trouble. Thanks again for the quick feedback!
If you remove the lock cylinder from the switch body, you can just use a flat blad screwdriver to move the switch betweed OFF, ON/RUN and CRANK. If the spring inside the bottom portion of the switch housing is bad, It will be bad and have trouble returing back to ON/RUN when you rotate it with the screw driver (lock Cylinder removed).
If the lock cylinder is bad and not free to rotate, *which is my probable cause) the plastic swith housing will allow you to easily rotate the switch in any position and properly spring back from start/crank back to RUN/ON.
C5 Ignition Switch Repair - CorvetteForum - Chevrolet Corvette Forum ...
LINK TO PIC:
https://www.corvetteforum.com/forums...dscf0046-1.jpg
SWITCH HOUSING. GREEN COVER houses the switches
The area just below the green part and the black ignition key cylinder tube is where the CAM and spring live:
NOTE! DO NOT take the cam/spring portion of the switch apart!! **** will go EVERYWHERE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Ask me how I know!
LINK TO LOCK CYLINDER PIC:
Does the "SECURITY" light stay on when you turn the key to "START"?
Honestly, I'm not fully sure I need a new one. 2002 MN6, driving home in a highway under construction and the Security light came on. Evidently, it's not locking, as if I jiggle the key slightly, all is well and the light goes off. Key pellet is not the problem. Light "Security" turns on intermittently. I just would prefer to not be stuck somewhere if it DOES decide to lock at one point.
I found the problem in my C5 was a bad battery.. I checked everything when I returned home after a trip. The car would not start after stopping at my mailbox, after jigging the key in the ignition switch and checking the clutch safety switch it started up. When I checked the car the next day the battery was dead..!! Replaced battery after noticing it was more than five years old.. (I write the installation day on all new equipment) I also changed the battery in my key fob.
These cars are very temperamental, always check the battery first, easier than tearing other things apart that are not at fault.
Best of Luck 🍀.. Happy 😃 motoring!
