Plug wire boots close to the header primaries...
Old Feb 26, 2008 | 04:39 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Default Plug wire boots close to the header primaries...
I put some TPiS longtubes on and the stock plug wire boots are close to if not touching the header primaries on some of the cylinders. Is this a concern and if so what can be done to protect them from the heat on these cars?
Old Feb 26, 2008 | 04:48 PM
vettenuts's Avatar
vettenuts
Either Koolsox or I used different wires.
Old Feb 26, 2008 | 04:51 PM
VIPERBLUELX
Did you reuse the metal sleeves?
Old Feb 26, 2008 | 05:28 PM
tiojames's Avatar
tiojames
Summit has a set that is semi-rigid that worked well on my vert. They cover everything from the head up.
Old Feb 26, 2008 | 05:45 PM
vettenuts's Avatar
vettenuts
No, it was a while ago. I think they are MSD.
To Plug wire boots close to the header primaries...
