Dimmer Wire
Old Mar 4, 2008 | 08:23 PM
D Lamberet's Avatar
D Lamberet
Default Dimmer Wire
I am installing a pillar of guages. I am looking to locate a dash light wire that is run thru the dimmer circuit. Anyone have pics or a post on locating said wire?
Danny
Old Mar 4, 2008 | 10:18 PM
middlebrookgt's Avatar
middlebrookgt
I found a couple of posts on the forum. You might want to check in the General and FI forums. Not sure where I found them, but was not able to get mine to work and ended up installing an LED switch so I can cut my gauge lights off when I don't want them. Good luck on your efforts!
Old Mar 5, 2008 | 02:29 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
See if this link works for you;
http://127.0.0.1:9001/servlets/RetrieveTif?pic=587052
Old Mar 5, 2008 | 10:16 PM
D Lamberet's Avatar
D Lamberet
Default Dimmer Wirre
Wow,
This is hard to believe. No body has ever ta[pped to the lighting circuit for a dimmer wire? The link posted above does not work any helpe here everybody?
danny
Old Aug 28, 2009 | 09:50 PM
JeremiahsC5's Avatar
JeremiahsC5
I have the same question. Anyone locate it?
To Dimmer Wire
