Is this a tranny problem?
In your OP you describe the problem as a "slip" ..... the ONLY item in the drivetrain of a manual vehicle that can "slip" is the clutch. The transmission is either IN GEAR or OUT OF GEAR. In gear, two (or more) gears mesh and they CANNOT slip. OUT OF GEAR is a condition that you might command, as in putting the gearshift in the NEUTRAL position, or it could be because something has broken in the gearbox .... either way ... the engine is COMPLETELY disconnected from the drive wheels ... nothing "slips" there just is no connection.
The C5 has some "clutch issues" when you take the car to the track and REALLY beat on it. Commonly people report issues such as stepping on the clutch pedal and finding that it does not return when they lift their foot from the pedal ... it stays on the floor. Others have reported a "soft" pedal, when they step on it the clutch does not disengage properly. Both of these are mechanical issues with the hydraulic/mechanical parts of the clutch.
Also, some people can create a clutch problem ... I have a couple of times observed people who, after a shift, leave their foot on the clutch pedal. When asked why they do this, they usually say something like ... "I'm gonna make another shift in a second or two, so it is easier to just keep my left foot there on the pedal". The problem with doing that is that just as often I've seen them partially (and unknowingly) depressing the clutch pedal as they corner and try and use their feet to help them stay in the seat correctly (How many times has your leg felt like it was gonna punch through that door speaker screen ??).
Partially depressing the clutch pedal will create slip in the clutch, and worse, the slip generates HUGE amounts of heat that then ensure the clutch will slip even when your foot is not on the pedal. I try very hard to keep my left foot on the footrest on the far left of the footwell ALWAYS .... the ONLY time my left foot comes off the footrest is for a shift ... as soon as the shift is done, I get my left foot back on the footrest.
If the car is driving "normally" now, I'm guessing (let me emphasize GUESSING) that you overheated the clutch at the track. It could be your tecnique, it could be the dreaded C5 "weak clutch" getting you .... but here's what I would do if it is driving OK now ....
1) As Bugs Bunny would say ... "unlax" ... all is fine. For street driving your car will continue to give you many miles of smiles.
2) When you go to the track again ... think about where your feet are (along with those 48 thousand other things you're trying to think about at the same time) ... and if the clutch starts slipping again ... do a "cool down" lap .... put the car in, say, 4th gear, and just cruise for one full lap in that gear. Wave people by in the passing zones ... the idea is to let your clutch and other parts of the car cool off by not "working" them for a lap. I bet you'll find the car is fine after a lap doing that.
Enjoy ... I've heard nothing but good things about what a cool track VIR is ....
DRIVE IT FOR A LITTLE MORE, AND PUT A LITTLE MORE PEDAL TO IT, IF THE CLUTCH, WITH TIME, IT WILL GET WORSE IN THE OTHER GEARS.
