Trunk problem.
Old Mar 6, 2008 | 08:42 PM
71vetteinva's Avatar
71vetteinva
Default Trunk problem.
I'm still new to my used C5 and I have a question about my quirky trunk.
When I use the trunk button inside the car the trunk opens about an inch or so all the way around. I can easily get my hand in there and lift it up.
When I use the fob the trunk lid barely opens. It's a little frustrating. I thought it might be the battery in the fob. It turns out the battery reads a perfect 3 volts on my meter. It doesn't appear to be bad at all.
Has anyone else had this problem?
Old Mar 6, 2008 | 09:03 PM
MagRedConv's Avatar
MagRedConv
This is a nit all have encountered, coupe and conv. I have a conv and unless I open the trunk AND close the door I get about a half an inch.
Old Mar 6, 2008 | 09:23 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
here's the popular fix:
http://www.c5trunkpopper.com/
if you have a hatchback coupe, you should get 2 (one for each side and to support the heavier hatch)
71vetteinva
Thanks for the quick reply. Sounds like something I need to get used to. No big deal, then.
Old Mar 6, 2008 | 10:32 PM
middlebrookgt's Avatar
middlebrookgt
spend the very few bucks on the trunk popper. It's terrific, takes 3 minutes to install, and I have never had another problem with my trunk lid
Old Mar 6, 2008 | 11:23 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Trunk popper works great. The reason the inside button works better is because when you press it you are standing outside your car - with the door open. When you use the clicker, the doors are closed. The car is air tight enough to create a vacuum effect. It's a very little vacuum effect, but that's all it takes. Either way, the popper will fix all your woes.
To Trunk problem.
