C5 died... :(
Old Apr 29, 2008 | 05:57 PM
  #41
sickvett's Avatar
sickvett
Ok so the throttle body seems disabled and I'm not getting fuel. Is there a way to bypass it? Somehow get power to the throttle body and injectors?
Old Apr 29, 2008 | 10:23 PM
  #42
sickvett's Avatar
sickvett
so you're all going to laugh, but I re-checked the fuses and somebody stole my fuel pump relay.. So I put one on there and.. well My injectors work again. Now.. I don't have any spark.. haha. If it's not one thing, it's the other. Anyway all the wires and the coil packs have power, but there is no spark.. Any ideas?
Old Apr 29, 2008 | 11:29 PM
  #43
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Check for your spark plug relay. Sorry, just had to
Old May 1, 2008 | 10:32 AM
  #44
BlackZ06's Avatar
BlackZ06
Even funnier ... there is one !!!!
The PCM uses relay 42 to power the coils. Check Fuse 16 as that protects the PCM circuit. Obviously make sure the relay is there. The fuse and relay are both in the underhood electric center.
Old May 1, 2008 | 02:42 PM
  #45
Joe0121's Avatar
Joe0121
St. Jude Donor '06
LMAO man you sand like me when I do work on my vette, everything goes wrong at once! Electrical problems re a PITA to chase down thats for sure.
Old May 12, 2008 | 04:50 PM
  #46
sickvett's Avatar
sickvett
So it's finally alive again! All it was was a ground not grounded properly. Go figure.. Anyway I'm cruising again so woohoo.. lol
Old May 12, 2008 | 06:05 PM
  #47
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Some how this whole thread seems to smell
Old May 14, 2008 | 09:53 PM
  #48
sickvett's Avatar
sickvett
Ok well.. maybe not. Everything is back together correctly and when I start it, it clunks, and then dies..
Old May 14, 2008 | 10:16 PM
  #49
Wisdom's Avatar
Wisdom
I've got a 4 cylinder '97 Sunfire sitting in my driveway that's playing with my mind the same way. But it sounds like you're having twice the amount of fun!
Did it run for any significant amount of time since the May 12 entry? New codes? Any chance the fuel pressure could be low and be starving it?
Old May 15, 2008 | 10:51 PM
  #50
sickvett's Avatar
sickvett
That's the weirdest part. There are no error messages. It sounds like it's coming from the engine, but I have full compression, so could it be the bottom end? Everything appears fine, it's just that when I start it it makes like a clunking sound and then after about 5 seconds it sounds like something is grinding, almost like when the pullys squeek. It's not the pullys though, my friend said sounds like a bad piston, but I dunno. I originally thought something was just loose, but it also eventually stalls. Any ideas?
