C5 battery disconnect switch
Old Mar 7, 2008 | 02:31 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default C5 battery disconnect switch
This is a new disconnect setup I made. Voltage loss from the remote mount disconnect switch is only 0.25VDC. The switch is a 200A Moroso, all brackets and mounts were made from materials I had lying around. This isn't the final appearance, as it is mainly the mockup. Power cable is 2/0 from batery to switch and back. Aluminum treadplate was used mainly for flexibility and strength (plus i had alot of extra). Drilled only 3 additional holes for switch and fuse holder, used cargo net studs in mounting also.
Switch backside
http://www.putfile.com/pic/7788855
Disconnect from driver side
http://www.putfile.com/pic/7788856?pos=top
Disconnect driver side #2
http://www.putfile.com/pic/7788857?pos=top
Disconnect control rod (fucntional tailight still)
http://www.putfile.com/pic/7788858?pos=top
Main power fuse mount (might modify and polish later on)
http://www.putfile.com/pic/7788859?pos=top
Side battery view and alt fuse holder
http://www.putfile.com/pic/7788861?pos=top
Flame suit on, but I really don't care.
Old Mar 7, 2008 | 03:04 PM
hotwheels57's Avatar
hotwheels57
Is this car strictly for racing? If so, it looks well thought out. If not, then I'd mount the disconnect somewhere else...pranksters.
The one thing that concerned me is the diamond plate mounted over the battery terminals.
Old Mar 7, 2008 | 03:33 PM
JoeyG's Avatar
JoeyG
The rod will be removed for non-track days. I'm going back to a side post only battery and the tread plate will be trimmed for additional clearance also. The tread plate is actually secured in three spots and is rock solid with no movement at all.
Old Mar 7, 2008 | 03:56 PM
hotwheels57
Old Mar 13, 2008 | 02:42 PM
JoeyG's Avatar
JoeyG
Updated pics here
http://www.putfile.com/album/180144?pos=top
Old Mar 13, 2008 | 04:24 PM
AU N EGL's Avatar
AU N EGL
Cool
Here is the one I just bought
http://www.pegasusautoracing.com/pro...asp?RecId=1464
Old Mar 13, 2008 | 05:38 PM
JoeyG's Avatar
JoeyG
Cool,never seen that one before. I only wonder about the contact termnal ratings:o
Old Mar 13, 2008 | 05:49 PM
AU N EGL's Avatar
AU N EGL
"This switch has three sets of contacts for cars with alternators. The main contacts disconnect the battery while the auxiliary contacts disconnect the ignition coil and short the alternator output to ground through a 3 ohm resistor that is furnished with the switch. A removable actuating key with splash guard, weather-proof cap, resistor and installation instructions are included. (Resistor lead configuration may vary from the photograph shown.) Don't forget to purchase an "Off" Decal (part #3356, sold separately).
Question: How do I know if I'm looking at the genuine article and not a lower quality clone?
Answer: The terminals of the genuine highest-quality switches are plated with a tin-alloy and are therefore silver colored. Lower quality clones have unplated brass terminals. In addition, genuine switches are shipped with half-height nuts while clones are usually furnished with full height nuts."
Here are the wiring diagrams
http://www.pegasusautoracing.com/Images/L/4430-inst.jpg
Old Mar 13, 2008 | 09:28 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Looks awesome Joey. Looking forward to seeing you and that hot rod in a couple of weeks. Here is a bump for ya!
To C5 battery disconnect switch
