Does anybody know if the 92mm is much better? What is this about having to cut the firewall? Has anybody dynoed one versus a 90mm? Would it be overkill on a 383 with good (not insane) heads? Thanks in advance!
I would assume this 92mm unit replaces the 90mm. If you have FAST 90 already I doubt very seriously the additional 2mm will make enough difference to justify a replacement. Just my $.02
This must be the 5th thread Ive posted this in but the bottom line is a 92mm FAST wont be worth a single HP over a 90mm FAST (all else remaining equal).
The restriction is not at the snout of the intake....its much further down the line related to the up and over runner configuration and the compromises in airflow that go along with it. Not to mention in the other direction your 90mm intake opening is already restricted by your MAF, airbridge, and other related items in front of it. The new manifold has stainless hardware (nice perk), a better TB gasket, and a pretty 92 mm logo on the front....and of course a new "buzz" in the marketplace.
Save your money and get the 90 if you can.....soon you wont have that option so all this fussing will be a mute point.
Tony
Tony
Thanks for the honesty Tony. I was hoping that you would chime in! Sounds like a 90mm will be fine for me.
