Help - Tunnel Plate Install Question
Old Mar 9, 2008 | 09:23 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Default Help - Tunnel Plate Install Question
Hi... I am replacing the stock tunnel plate with a 3/8's aluminum plate...
Question, should I use locktite on the bolts?? I'm thinking of using the Blue ( medium ) strength... I will be installing lock washers..
Any recommendations???
BTW when I removed the stock piece the factory bolts were barely tight and I could literally back them off with my fingers!!
Old Mar 9, 2008 | 10:12 PM
VettRick's Avatar
VettRick
It probably wouldn't hurt anything to use medium LockTite.
Are you going to re-use the stock bolts?
I re-used mine and they were just barely long enough.
Rick
Old Mar 9, 2008 | 11:02 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I purchased longer bolts to accomodate the additional thickness of the aluminum & lock washer...
Old Mar 10, 2008 | 01:15 AM
lucky131969's Avatar
lucky131969
If you're using a lock washer, why to you need the loctite? Redundant......
Old Mar 10, 2008 | 02:59 AM
Speed Trap's Avatar
Speed Trap
I always use locktite on just about everything. Comes from working on Harley's. It's just a bit of extra insurance that the nuts/bolts won't come loose.
Old Mar 10, 2008 | 06:11 AM
vettenuts's Avatar
vettenuts
I wouldn't, I didn't on mine and it was tight next time removed. Factory doesn't use it either. There are quite a few bolts, so removal next time with loctite will be fun.
Old Mar 10, 2008 | 10:42 PM
Brad@RevXtremeAutoSports's Avatar
Old Mar 10, 2008 | 11:24 PM
rws.1's Avatar
rws.1
From CCA's web page....
Tighten all tunnel plate bolts to 86 inch/pounds of ( that is jus tover 7 ft-lbs) torque, or 1/2 turn past snug. (Do not over tighten, you will strip these bolts.) In this case, extra tight does not add to product performance.
Old Mar 12, 2008 | 05:54 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Thanks for the info/comments...Tunnel plate is now installed with no issues.....
To Help - Tunnel Plate Install Question
