Lowering and Alignment Question
Z06 Service Manual Alignment --- Source
LEFT & RIGHT FRONT:
Camber: Specified Range: -1.2 to -0.2 Optimal: -0.7
Caster: Specified Range: 6.4 to 7.4 Optimal 6.9
Toe: Specified Range: 0.15 to 0.25 Optimal 0.20
FRONT
Cross Camber: Specified Range: -0.5 to 0.5 Optimal: 0.0
Cross Caster: Specified Range: -0.5 to 0.5 Optimal: 0.0
Total Toe: Specified Range: 0.30 to 0.50 Optimal: 0.40
LEFT & RIGHT REAR
Toe: Specified Range: -0.06 to 0.05 Optimal: -0.005
REAR
Total Toe: Specified Range: -0.11 to 0.09 Optimal: -0.01
Thrust Angle: Specified Range: -0.10 to 0.10 Optimal: 0.00
**edit**
I just pulled these out of the "search", anyone running these with a similar suspension setup , if so how do they like
these are from : SDWYZ C5 "Mild - Mildy Aggressive"
Front Individual Toe +0.03 degree +0.03
Front Sum Toe +0.06 degree +0.06
Steering Wheel Angle 0.0 degree 0.0
Front Individual Caster +6.9 degree L +6.72 R +6.86 AVG = +6.79
Front Cross Caster within 0.50 degree
Front Individual Camber -1.0 degree L -0.83 R -0.79 AVG = -0.81
Front Cross Camber within 0.50 degree
Rear Individual Toe 0.0 degree L 0.0 R -0.01 AVG = -0.005
Rear Sum Toe 0.0 degree -0.01
Rear Thrust Angle 0.0 degree 0.0
Rear Individual Camber -0.80 degree L -0.68 R -0.73 AVG = -0.705
Rear Cross Camber within 0.50 degree
Cheers!
Kasp
LEFT & RIGHT FRONT:
FRONT
LEFT & RIGHT REAR
REAR
I just got a set of SP500's and needing an alingment badly. My original wheels/tires I took off were SHOT on the inside of all 4. I mean down to the belts ! The outside of all 4x tires still have some wear before hitting the wear markers. I got it aligned 1.5 yrs ago at the dealership but it seems it was not done right
. I lowered it even more latey with C6 bolts, and longer bolts in the rear.Your data should help when going to the alignment shop that LG's told me to go to.
Thanks !
Toque
Thanks !
Toque
Abraswell:
Thanks for the added info !
I love this forum !
Thanks !
Toque
Thanks !
Toque
I posted a few pics on this post.
http://forums.corvetteforum.com/show....php?t=1962315
Toque
Toque
