Need Help Choosing Heads
Old Mar 17, 2008 | 08:31 AM
9secondflat's Avatar
9secondflat
to turn 126 with factory untouched heads....again, its not that i dont believe you, its that there are hundreds of c5's with head cam package's that have been built with everything from trickflow, afr, etp, and every co that cnc the ls6 and ls1 heads that dont turn that mph....you quite possibly may be a bit dissapointed by bolting on a set of cnc'ed ls6 heads, spending a couple of grand and not gaining any hp...
Old Mar 17, 2008 | 08:40 AM
badazzEBz06's Avatar
badazzEBz06
bro u dont have to believe me u can ask the dude @ race proven motorsports. hopefully i will make some hp i can pretty much guarantee it im goin with the livernois stg2 heads they obviously flow better than stock ls6 heads so i dont see how i cant make hp off them
Old Mar 17, 2008 | 11:18 AM
nickolbag's Avatar
nickolbag
I'm betting that 126 trap will come down significantly with a good set of tires. Spinning all the way down the track is a good way to inflate the trap speeds. All the Cartek and VD cars you compare this to are properly set up for the track which is reflected in the ETs they turn out.
