Changing fluids?? Trans and Diff.....
Old Mar 14, 2008 | 02:59 PM
whitelite's Avatar
whitelite
Default Changing fluids?? Trans and Diff.....
This looks very straight forward but I have learned too many pearls of wisdom on this forum not to ask!!!!
Any words of wisdom on changing Trans and Diff fluid besides pull the drain plug and drain trans, replace plug and fill to brim through upper plug.
Repeat with differential.
Thanks,
Randy
Old Mar 14, 2008 | 08:39 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Trans fills from the side, not top. Same with differential. Make sure you use the GM Additive with your diff oil - or get Royal Purple pre-mixed.
Stephen
Old Mar 14, 2008 | 11:37 PM
rustyguns's Avatar
rustyguns
Thanks,
Randy
Thats it! i run royal purple syncromax in tranny and redline 75/140 (blue) shock oil in differential, already has additive
Old Mar 15, 2008 | 12:33 AM
p_dubya's Avatar
p_dubya
Just make sure you remove the fill plug BEFORE you remove the drain plug. Don't wanna get stuck with drained fluid and a seized fill plug. Also, make sure you have a good hand pump for the fluids...there's no way of a pouring out of the bottle.
I just did mine today for the first time. It's really really easy.
Old Mar 15, 2008 | 10:40 AM
whitelite's Avatar
whitelite
Now there's some words o' wisdom...........
Thanks, Randy
To Changing fluids?? Trans and Diff.....
