Another Oil Catch Can question
Old Mar 17, 2008 | 07:27 AM
C5SMAJ's Avatar
C5SMAJ
Default Another Oil Catch Can question
Ive done a search and now know more than I ever wanted to on catch cans...!!!...however I dont find an answer to my specific question....I have a Oil Catch can....inline with the PCV....but there is another hose that comes out of the valve cover and runs directly to just behind the throttle body....seems to me that unless that line also runs thru a catch can having the one attached to the PCV line really only cures half the problem......am I missing something....regarding that second hose...
thanks......
Old Mar 17, 2008 | 07:43 AM
LoneStarFRC's Avatar
LoneStarFRC
Yes, you are. The hose you're referring to allows filtered air into the crankcase. The air is flowing from the throttle body area to the engine. Do not route it to the catch can.
HTH
Old Mar 17, 2008 | 07:45 AM
LDB C5's Avatar
LDB C5
There should be 2 lines; one connected to the throttle body, and one in front of that connected to either the coupler or the air bridge. The line connected to the coupler is the fresh air intake for the crankcase. The catch can goes into the line that connects to teh TB.
Old Mar 17, 2008 | 08:13 AM
lucky131969's Avatar
lucky131969
I'm not sure how you have yours setup, but I'm not familiar with a line going to the air bridge or coupler. On a factory setup, the fresh air intake runs from the throttle body to the valve cover, and the PCV valve runs to the intake manifold on the passenger side.
Old Mar 17, 2008 | 08:26 AM
C5SMAJ's Avatar
C5SMAJ
HTH
ah ha....!! I knew there was something I was missing....thanks all for the input.....I was about ready to buy another can....I saw it somewhere where someone siad you need two cans.....I think maybe he was in same boat as me......thanks again all.....
larry.....
Old Mar 17, 2008 | 08:32 AM
lucky131969
larry.....
Make no mistake about it, the fresh air line will backflow given enough crankcase pressure. You probably don't have to worry about it as much as FI guys though.
Old Mar 17, 2008 | 08:42 AM
LoneStarFRC
Since he made no mention whatever of a huffer etc, I stand by my recommendation.
Old Mar 17, 2008 | 08:45 AM
lucky131969
Old Mar 17, 2008 | 09:17 AM
Cujo67's Avatar
Cujo67
http://forums.corvetteforum.com/show...ghlight=cujo67<BR>
Try this link, it might help.
To Another Oil Catch Can question
