Rear end leak
Old Mar 20, 2008 | 12:14 PM
BATM4N's Avatar
BATM4N
Originally Posted by vettenuts
If the rest of the car is really good, you can use it as a bargaining chip. If the rest of the car is telling you there was some abuse, then move on. Unfortunately, many cars (even those that were babied) had this problem and it is pretty common. .
Good advice here because its only a $300-400 fix and if you buy one that hasn't leaked yet, it will leak sooner than later and then you didn't even get any money off of the price of the car.
Old Mar 20, 2008 | 12:24 PM
02gt350's Avatar
02gt350
man, its common. its not expensive unless the case is cracked, and if it was, it have fluid all over the place. MQQn is correct, there is no O ring. (i just did mine 2 weeks ago) my stocker actually had to sealant at all. I used super high temp RTV between my new 4.10s and tranny with my DTE brace.
if its on the halfshafts the job just got 100X easier. you can have one of those seals replaced in 20 minutes. if its leaking between the diff and tranny, its more work, but if you do it yourself, its free...just 5 bucks for a good silicone
Old Mar 20, 2008 | 01:03 PM
RRR Racing's Avatar
RRR Racing
Alot of good advice here. I plan on looking for another one unless he gets the issues fixed. I liked the car a lot and it looks real good but I dont want to get stuck in a nightmare. I have 24k to 25k to spend and I want a Z06. This was was nice because it was local and I thought the mileage was good (42k). I didnt want to travel across the US to find one.
Old Mar 20, 2008 | 02:08 PM
lucky131969's Avatar
lucky131969
Well, I'll tell you what....look up GM p/n 12369456 and tell me what it's for........
Old Mar 20, 2008 | 02:18 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Mike -
I think I have found a partial answer -
http://www.allworldautomotive.com/au...ts8005-33.html
Originally Posted by www.allworldautomotive.com
expand 12369456 RETAINER DIFF CARR SEAL 6 $5.96
Alt #: 1997-1999
Packaging:
Application: CORVETTE
expand 12369457 RETAINER DIFF CARR SEAL 1 $6.70
Alt #: 1998-1999
Packaging:
This part number is only for 97-99 - so yours might have these and the later carriers did not?
I can tell you positively that the later carriers do not use an o-ring on the mating surface between the trans and the carrier. Reference the picture I posted above - did the business end of your carrier look like the above?
best regards -
mqqn
Old Mar 20, 2008 | 02:28 PM
lucky131969
Originally Posted by mqqn
Hi Mike -
best regards -
mqqn
The parts manual I have only goes up to 2002, and that part number is good for 97-02 with a manual tranny. The o-ring is on the tranny side, not the differential. If you took a pic of the tranny side, you would see it. I'm thinking no one ever pays attention to it. I had to order it when I replaced installed my new RPM diff.
Old Mar 20, 2008 | 02:30 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Mike -
You could be right there - I will look at my pictures tonight - I took tons of pics but they are all on my personal laptop....I am supposed to be working lol...
At any rate - for RRR's purpose, this would be just as easy either way - o-ring or no o-ring - the R&R would essentially be the same.
Lucky's point about a broken carrier or trans is a valid one - since the car has had a forced induction system on it....
best regards -
mqqn
Old Mar 20, 2008 | 03:00 PM
RRR Racing's Avatar
RRR Racing
Thank's guys, He came down another $500 So I think I will take a chance on it. I have been working on and racing cars for years so I will attempt the repair. Nevertheless I wont continue to drive it with a "leaky Butt" I'm pretty sure I can do the work but I may need some direction from you guys. Thanks for all the help on this matter, Rick http://www.rrr-racing.com/index.htm
Old Mar 20, 2008 | 03:40 PM
02gt350's Avatar
02gt350
i will have to look now cuz ive taken apart a 2001 and 2002 and there was no said seal. both stock units
Old Mar 20, 2008 | 04:44 PM
vettenuts's Avatar
vettenuts
On the MN6, there is an o-ring between the transmission and the differential. I have changed it on every swap so far, although many don't.
Old Mar 20, 2008 | 04:55 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Thanks vettenuts and lucky -
So - Ryan - you did not notice the o-ring on that, where did you read that we you needed to use the sealant? I thought it was in my manual....
I don;t think that would HURT - unless that silicone got into the diff case, it might cause problems - I would not want that in my diff.....
Thanks for the info and correction guys - I appreciate it.
best regards -
mqqn
Old Mar 20, 2008 | 06:54 PM
02gt350's Avatar
02gt350
best regards -
mqqn
the bead went where you see the bolts. there is still a lip on the tranny. no way its getting in there, and if so, it just get chewed up...no biggie.
Old Mar 20, 2008 | 10:44 PM
  #33
lucky131969
So has anyone found out where this mysterious service manual instruction is to seal this surface? There is no sealant used on this surface, nor is there intended to be. I also check the TSB's, and nothing regarding this surface. There is a TSB for using sealant on the side covers, and for the transmission/ transmission extension interface, but nothing for the transmission extension/ differential carrier interface.
I can't help but wonder how many guys don't even know that gasket exists, and just RTV the SH$# out of the surface.....
Old Mar 20, 2008 | 11:13 PM
  #34
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi lucky -
No - there is no mystery - I was wrong and the manual does not say this, and there is a o-ring as you originally asserted, but it is on the boss of the rear of the transmission, and not on the differential (not that you ever said so - that is what I was thinking I would see....)
The o-ring seals against the inside surface of the carrier, and can be easily replaced.
Ryan used silicone on his, but that will not hurt a thing.
And, here is a picture of Ryans trans that I took while it was out and lying on my garage floor - you can see his has an o-ring just like you and vettenuts said.
Thanks again to you and vettenuts for the information - I am always willing to learn more and that is why I am willing to question things when I am not sure, or when I think something else is true.
best regards -
mqqn
Old Mar 21, 2008 | 12:32 AM
  #35
lucky131969
Hi lucky -
best regards -
mqqn
Yep, the seal was only $12.73. Cheap insurance in my book
Old Mar 21, 2008 | 01:06 PM
  #36
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi lucky -
So - looking at this junction of the diff to the trans, it seems that the diff fluid could get into that area through the opening to the side of the hole that the transmission output shaft inserts into.
I wonder if there should be gear oil in that cavity?
Also, if one saw trans fluid leaking out of there, that would indicate a rear seal on the transmission was bad, as well as the o-ring around this junction.
best regards -
mqqn
Old Mar 24, 2008 | 06:52 AM
  #37
RRR Racing's Avatar
RRR Racing
Thanks again. I bought it. I got another $500 off for the leak. He also gave me three large manuals for the 01 Z06. It has step by step instructions for the diff removal. I'm sure I can get it out and back in.
To Rear end leak
Old Mar 24, 2008 | 12:52 PM
  #38
FRCTony's Avatar
FRCTony
Does anybody have links to the procedure for resealing the side covers?
Old Apr 3, 2008 | 03:25 PM
  #39
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Lucky -
Here is where I read this - it is not in the manual, it is in a TSB as you indicated - here is a link -
http://www.corvetteactioncenter.com/...over+Flange%29
"Engineering has recommended the use of a sealant..."
The above is for the side cover, and not the diff to trans junction.
best regards -
mqqn
Old Apr 13, 2008 | 11:56 AM
  #40
Motohead1's Avatar
Motohead1
Not to hijack this thread but thought I might ask if there are any "might as well" parts to replace or upgrade when replacing that trans o-ring? I just picked up a 00 FRC and its leaking there.
Also can the rear trans seal be replaced from that end?
