Nitrous Explosions
Old Dec 16, 2001 | 02:45 PM
Chris@SD's Avatar
Chris@SD
Default Re: Nitrous Explosions (Wt99C5)
Over the years I have seen hundreds nitrous explosions. Two of them the cars were burned to the ground and the driver barely made it out with their lives. One eplosion happens 2 years ago and I remember it like it was yesterday. The fire took only seconds to go from the front to the rear of the car, and nobody could get to the driver. Oh ! These guys were/are nitrous experts.
I want to go fast, but I want to do it next week too.
How can an inert gas cause a fire to engulf a car in flames in seconds. Sounds like there are other factors involved that people like to blame on nitrous.... :(
I can't believe the idiot with the nissan nitrous explosion pictures have not made it here yet... :( :(
Old Dec 16, 2001 | 02:52 PM
olephart's Avatar
olephart
Default Re: Nitrous Explosions (Chris@SpeedDemon)
Nitrogen is inert. N2O is not. If it was, it wouldn't do anything but take up space the gasoline could be using.
Old Dec 16, 2001 | 03:00 PM
Chris@SD's Avatar
Chris@SD
Default Re: Nitrous Explosions (olephart)
Nitrous will not release it's extra oxygen molecules unless subjected to extreme pressures and heat. At that time, the chemical bonds are changed and essentially you are no longer dealing with nitrous.
Nitrous oxide is inert. :)
Old Dec 16, 2001 | 03:05 PM
Austrian Vette's Avatar
Austrian Vette
NOS cars exploding??
Someone has seen "the fast and the furious" too often.
Old Dec 16, 2001 | 03:12 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Nitrous Explosions (Austrian Vette)
DA Juice :(
Old Dec 16, 2001 | 03:17 PM
Wt99C5's Avatar
Wt99C5
I agree, but the nitrous explosion was so violent that it lifted the hood. From what I understood it ruptured the fuel line at the carb. The fuel was shut off in a matter of seconds, but the fire was already at the rear of the car. I think the driver was actually knocked out for a short time. Serveral nitrous cars had problems with backfires that day, you would not believe how fast they were out of their cars. Maybe weather conditions can create nitrous backfires.
Old Dec 16, 2001 | 03:22 PM
Austrian Vette
What cars were these??
Not NOS cars like ours??????
Michael
Old Dec 16, 2001 | 03:59 PM
Wt99C5's Avatar
Wt99C5
Full race cars, built for nitrous.
I don't know which brand. They run a lot of NOS and Nitrous Works around here.
Old Dec 16, 2001 | 04:06 PM
olephart's Avatar
olephart
OK with me if you have some street definition of an inert gas. I don't think they are going to change the chemistry books to accomodate you though. :D
I guess you mean that it doesn't do much in it's free state.
Old Dec 16, 2001 | 04:33 PM
Austrian Vette
That´s what I was thinking.
I don´t think a 150 shot NOS C5 will go up in flames, whatever happens.
Not even one of our 200hp directports.
There maybe a blown MAF, maybe a damaged intake,burnt/broken pistons or broken rods, maybe a damaged core but that´s the worst case, I think.
Michael
[Modified by Austrian Vette, 9:34 PM 12/16/2001]
Old Dec 16, 2001 | 04:57 PM
Chris@SD's Avatar
Chris@SD
OK, I agree. Inert is the wrong term. What I am implying by saying this is that Nitrous will not burn.
Old Dec 16, 2001 | 05:20 PM
Wt99C5's Avatar
Wt99C5
Yes, I have no idea what they were using. I see NOS/Holley has a 1000 shot system. The backfire and results of the backfire are what causes the problems. Can a solenoid or switch stick, even on a 100 shot? What would be the results? I would buy the best parts money can buy. By the way, I don't believe nitrous is cheating either. The auto makes have used turbos and blowers over the years, but I've never seen one on the bottle. Why?
Should I learn something from that?
Old Dec 16, 2001 | 10:51 PM
  #33
2ndVette's Avatar
2ndVette
I love these Nitrous horror stories. They are almost as good as old Lan Chaney movies...
Old Dec 16, 2001 | 11:19 PM
  #34
OSR 1's Avatar
OSR 1
little tip i learned the hard way,i run 2 systems on my car total of about 225 hp
and have had a couple of what i call small intake pops.
it would blow the nitrous foggers off the intake and leave a mark on under hood mat
when that happens if you dont catch it right away it could spray fuel on the motor and cause a fire
the fix is if you take the clamp off the vaccum hose that goes to the brake booster when the motor pops thru the intake it blows the line off the booster now and not the nitrous
Old Dec 16, 2001 | 11:49 PM
  #35
C5Cemo's Avatar
C5Cemo
Default Re: Nitrous Explosions (OSR 1)
Excellent tip! Thanks
Old Dec 17, 2001 | 12:04 AM
  #36
C5Cemo's Avatar
C5Cemo
Default Re: Nitrous Explosions (C5Cemo)
Wait...will the car stop safely with this idea :crazy: Maybe a vacuum canister can be added for this purpose, kinda like a blow-off valve?
:cheers: :smash: :lol:
Old Dec 17, 2001 | 11:19 AM
  #37
OSR 1's Avatar
OSR 1
when the line comes off there is plenty of brakes to stop the car safely
when i started running large amounts of nitrous it popped all the time
Old Dec 17, 2001 | 01:04 PM
  #38
Austrian Vette
I have installed a vacuum shift modulator on my FLP tranny, that uses the engine vacuum for shifting firmness.
It has a valve that opens if pressure is too high.
It was built for safety with turbos, but should work on that NOS pops also :D
Michael
