Nitrous Explosions
Old Dec 9, 2001 | 05:22 AM
flynbludream's Avatar
flynbludream
Default Nitrous Explosions
I was reading in a magazine tonight about bad things that happen to nitrous people when for example, they spin off the line and get off the throttle. This causes the fuel to stop spraying but not the nitrous and thereby results in an extremely lean condition when they get back on the throttle making nice little paperweights out of your pistons. Makes sense to me, but my question is, does this only happen with "dry" kits? Seems like a wet kit would have less of a problem with this since you are also spraying fuel with the nitrous. Any info appreciated. Oh BTW they said if you run into this situation, you had better just shut it down, but for how long? I am figuring that the nitrous will eventually break down in your intake so it would be safe to start up, but how long does that take?
Thanks for helping a nitrous rookie.
Old Dec 9, 2001 | 05:52 AM
C5Cemo's Avatar
C5Cemo
Default Re: Nitrous Explosions (flynbludream)
Sounds like a tall tale by a non-nitrous user.
All of the kits today, whether wet or dry. function off of a WOT switch so if the throttle gets backed off due to wheelspin, the nitrous solenoid will close as well...no WOT=no N20.
The only thing that compares in my mind with these "findings" is when someone unfortunately leaves their traction contol on and has the basic WOT switch...it will keep spraying even though the engine is not at WOT. This scenario can be irradicated completely with the BPP WOT switch, though. It is an electronic switch that reads the TPS instead of being just a basic switch.
As far as downtime, it is always recommended to not start a engine that has recenlty been flooded with nitrous for whatever reason. To be safe, some pull all of the plugs and crank it over to release it all. This is the worst case scenario. Normally if you accidentally spray a small amount of nitrous into the engine when not running it takes no time to clear out especcially if the throttle is closed.
:cheers:
Old Dec 9, 2001 | 08:07 AM
Austrian Vette's Avatar
Austrian Vette
Just be sure to have all goodies then NOS will be save.
Getting off the peddal and still spraying NOS means there is no WOT switch installed. That´s crazy and so poopie may happen.
Again, get all goodies and don´t spray too much NOS.
Then it is save.
Michael
Old Dec 9, 2001 | 09:36 PM
flynbludream
Default Re: Nitrous Explosions (C5Cemo)
C5memo,
Just telling you what I read in the magazine. Maybe it was an older plate nitrous system or something. Thanks for the info.
Old Dec 9, 2001 | 10:13 PM
MelloYellow's Avatar
MelloYellow
This might be a descript of the dreaded Nitrous backfire when fuel or nitrous puddles in the intake.
As far as getting nitrous out, I think you have to cold crank the engine. I'm kinda tired right now, so take this with a grain.
Old Dec 9, 2001 | 10:54 PM
Second Childhood's Avatar
Second Childhood
As the others have stated you MUST have a WOT switch.
Other safety features:
On and Off regulator. Get an MSD that lets you install RPM pills to turn the nitrous On (eg. 3000 RPM) and Off (eg. 6000RPM). This can help with traction, missed shift, and allows the engine to be cranking before you hit it with the juice.
Low fuel pressure off switch. If the fuel pressure drops below a determined level the nitrous will not flow.
Old Dec 9, 2001 | 10:58 PM
jschindler's Avatar
jschindler
Default Re: Nitrous Explosions (Second Childhood)
Anyone who runs nitros gets what they deserve :lol:
Those of us who don't have it, and are afraid of it, consider it cheatin. Kind of like Karl Malone. He plays dirty. But if he played for my team, he'd be the most awesome player that ever lived. :cheers:
Old Dec 9, 2001 | 11:51 PM
CliffB-99's Avatar
CliffB-99
Default Re: Nitrous Explosions (jschindler)
This past spring at the C5 B'day bash in Bowling Green, I was in the staging lanes at Beech Bend dragway when a C5 (in line about 20 feet behind me) with nitrous blew up and caught fire. The explosion blew a nice hole in the composite plastic intake. Don't know exactly what happened, but the explosion was enough to convince me to never add nitrous to mine. my .02
Old Dec 9, 2001 | 11:59 PM
jetskifast's Avatar
jetskifast
Default Re: Nitrous Explosions (CliffB-99)
CliffB-99
Very interesting how Nitrous blew up and caught fire. Nitrous is non-flammable
Old Dec 10, 2001 | 12:06 AM
CliffB-99's Avatar
CliffB-99
Default Re: Nitrous Explosions (jetskifast)
CliffB-99
Jetskifast- You shouldn't read so fast. I clearly stated the C5 blew up, not the nitrous. I'm not a nitrous expert like you, so maybe you can explain how nitrous kits sometimes trigger explosions like the one I saw.
Old Dec 10, 2001 | 12:44 AM
jetskifast's Avatar
jetskifast
CliffB-99
Most nitrous systems are setup to activate at WOT only. Floor mounted micro switch or elecronic N20 activation are most common activation switches. Some owners do use hand held on/off switch.
Since C5 sounds like it was lined up in front of you, not at WOT, problem may not have been nitrous related.
Intake could explode if you have a build up of nitrous inside intake manifold, from some sort of failure, such as solenoid leaking N20. Back fire when spraying N20 could also do a job on your intake.
Old Dec 10, 2001 | 01:42 AM
Viprklr's Avatar
Viprklr
CliffB-99 -- Nice lift man!!! Wish I had one. :yesnod: :chevy
Old Dec 10, 2001 | 01:52 AM
C5 YA's Avatar
C5 YA
While using N20, it's all about the safety switches to eliminate any possibility of N20 damage. This incluse WOT switches, Window (RPM) switches & pressure gauge. W/ all these in place and a correctly installed N20 setup, only real damage that can be caused to a stuck solenoid.
Old Dec 10, 2001 | 02:15 AM
CliffB-99's Avatar
CliffB-99
Default Re: Nitrous Explosions (Viprklr)
Actually, it's my friend and fellow Vette-nut Gary's lift. Wish I had one to. They're not as expensive as you might think. This model was a little over $3K.
Old Dec 16, 2001 | 04:46 AM
flynbludream
Here's a bad thing.
http://gearmedia.ign.com/media/hardc...e_11232001.mpg
Old Dec 16, 2001 | 10:22 AM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Whew.. got any more of that video after the flame burst? The flame appears to originate IN FRONT of the radiator???
Old Dec 16, 2001 | 10:51 AM
Austrian Vette
Default Re: Nitrous Explosions (nevrenuf)
I know about that car.
The car was detonating worse bevore that run.
They wanted to know anyway.
I think it was a dead plug because of the high NOS shot
(150wet+50 dry, or so).
So they sprayed with a damaged plug.
It HAD to backfire.
The backfire blew off the airfiltercase.
If I remember right, the car ran after that.
The guy only had to pull the plugs and put in new ones.
He was lucky.
Don´t play with NOS and you´ll be safe.
Michael
To Nitrous Explosions
Old Dec 16, 2001 | 11:10 AM
Skeeter1's Avatar
Skeeter1
:lol: :lol: :lol: :cheers:
Old Dec 16, 2001 | 11:54 AM
Wt99C5's Avatar
Wt99C5
Over the years I have seen hundreds nitrous explosions. Two of them the cars were burned to the ground and the driver barely made it out with their lives. One eplosion happens 2 years ago and I remember it like it was yesterday. The fire took only seconds to go from the front to the rear of the car, and nobody could get to the driver. Oh ! These guys were/are nitrous experts.
I want to go fast, but I want to do it next week too.
Old Dec 16, 2001 | 02:34 PM
Austrian Vette
Default Re: Nitrous Explosions (Wt99C5)
UUUUUUHHHHHHH, hoororstory! ;)
