C5 noise
Old Mar 27, 2008 | 08:32 AM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
Default C5 noise
I just traded in my 1994 and bought a 2002 pewter/black auto with 27k miles.
It's an awesome car with almost all of the options. What a difference, C-4 to C-5.
When I first start the car cold, it sounds like a diesel motor for about a minute. This I understand is piston slap, but my questions is, should I let it idle until warm or is it ok to drive like this? Is it doing any damage?
Also, the tire pressures on the DIC range from 29-31 degrees for pressure. Is this normal as the tires get warmer, or should I have it re-calibrated? Once I've been driving a while the pressures stay steady. It seems to change when tires are cold.
See you at the show and shines.
Thanks.
Old Mar 27, 2008 | 08:40 AM
Blown 346's Avatar
Blown 346
Thanks.
It doesnt do any damage, I myself would wait for it to stop before I drive it.
As you drive the car, the tires will warm up and the air pressure will increase.
Old Mar 27, 2008 | 09:55 AM
Mike Mercury's Avatar
Mike Mercury
the only way to recalibrate the tire sensors... is with replacing them. (not that I think yours are malfunctioning in any way).
FYI; the tire pressure reporting system on the C5 is not intended to be a scientific measurement device. It's mainly to tell you whether your run-flat tires have zero pressure or not (since the driver may never be able to notice).
Old Mar 27, 2008 | 03:13 PM
Dave68's Avatar
Dave68
What viscosity oil is in your engine? If it's too thick at startup (like 20W-50), that could be your problem. Use 5W-30 (preferably), 0W-30 or 0W-40 for protection at startup (and almost any temperature you can throw at it). having a good high-flow oil filter like the K&N is another way to get the oil circulating quickly upon startup.
Old Mar 28, 2008 | 08:18 AM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
Default Engine noise
Thanks everyone. I appreciate the info.
To C5 noise
