car stalled and wouldn't keep running
I had a mild cam put in my car along with a UDP and a dyno tune serveral weeks ago at Ed's shop in Chesapeake. since then I've noticed that the car was slightly easier to stall than it used to be. I don't know if this is relevent or not, but there's some history.
I had a small leak code on the EVAP system a couple weeks ago, refueled and made sure the cap was on tight and that problem went away also.
today I drove home for lunch and my car stalled while making a turn into my driveway. I figured I just let the RPM's drop too much. it started up and I parked. I got back in to head back to work and my car would not run well. if I reved it it would rev up then drop down to 300 or so and start to bog, but then would return to normal. rpm's were in the 500 range as I backed out of my driveway and then headed down the road. I stopped at the stop sign and it stalled. I went through this several times, it would start right back up, run rough at 400-500rpms then it would stall unless I gave it some throttle. I turned around and went back. it would run just fine as long as we were moving, but it would not idle unless I gave it some throttle. worried about this I shut it down and went to get something to write down the codes. there was no MIL, and no codes of any significance. I had cleared them about a week and a half ago. I had 2 SCM codes, and an RFA code, U 1016 H which I believe is a loss of communication, and also probably doesn't have anything to do with this. I didn't clear the codes. I restarted the car and then everything magically went away. it would idle at 700, and if I revved it the rpms would only drop to 500-600 as they came back down then they would stabilize at 700-750.
what gives? should I be concerned about this? Should I check something?
its hot out today and the A/C was probably working more than it has been for the last several months, but its not even that hot yet, I don't see why that would make any difference. if anything the UDP should make the car feel less of a burden from accessories than before. something in the tune? something completely unrelated?
please help!
I recommend you let Ed do some scanning to make sure that the LTFTs are correct and all the other variables that control idle are working properly. I would also make sure that the air pluming between the TB and MAF are all air tight.
BC
God Speed
