Road trip cut short
Old Mar 29, 2008 | 12:40 PM
Numb's Avatar
Numb
Originally Posted by Veni, Vidi, Vert
Sorry to hear that. Just out of curosity, was the spring broke near the top or in the middle??
In the middle if I remember correctly. I'll take some pictures as I take it apart today.
Old Mar 29, 2008 | 12:53 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Hopefully it's just a valve and you'll be back on the road quick. I'm only an hour or so away, let me know if you need a hand.
good luck !!
Old Mar 29, 2008 | 04:02 PM
ALLEGRO's Avatar
ALLEGRO
Though I am really sorry to hear of your problems, there is a "silver lining" to this all. It sounds like you now have great excuse for an LS7 or hotter mill.
At least revel in "what might be."
Old Mar 29, 2008 | 04:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Hopefully it's just the the valve or head that is damaged and you can pick up a used set of heads cheap.
Old Mar 29, 2008 | 08:16 PM
Numb's Avatar
Numb
Man, I can't belive it, but it looks like other than the valve spring, nothing else broke! The valve spring snapped right in the middle, but there isn't a scratch on either the valve or the piston... nice, normal looking carbon coating. How is that even possible?? I have some nice pics of everything, but I don't have my camera cable with me.... I'll have to post them later.
Soooooo, it's already taken apart, and LG Motorsports is right down the road - I pretty much HAVE to put it back together with one of their G5X3 cam/spring kits.
Old Mar 29, 2008 | 08:23 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would still have the head checked to make sure that the valve or valve seat did not get damaged (that you can visually see). I guess the valve never dropped all the way down but just didn't have enough pressure to close the valve causing the mis-fire.
Good luck getting it fixed up.
Old Mar 31, 2008 | 12:14 PM
Boob's Avatar
Boob
Get it to a machine shop and have the valve guide checked to see if it's within spec all is good. Glad to hear it didn't cost you a shortblock.
Old Mar 31, 2008 | 01:00 PM
LDB C5's Avatar
LDB C5
I feel a pair of Trick Flow's in your future.................
Old Mar 31, 2008 | 07:31 PM
Numb's Avatar
Numb
Well, if you're going to take your car apart, you might as well put it back together a little better. I drove down the road to LG Motorsports today, and they just so happen to have everything you could possibly want in stock... you really don't stand a chance. I drove off with:
LG Pro long tube headers
G5X3 v2 cam
Comp valvetrain kit (921 springs, ti retainers, pushrods, seats, etc)
ASP underdrive pulley
Vararam B2
ARP head bolts
I also picked up some .040 Cometic head gaskets, and at LG's recommendation, I'm going to mill the head down to 59cc and flycut the pistons.
Looking forward to getting it back together to see how much of a wakeup the Z06 is in for.
Old Mar 31, 2008 | 08:47 PM
motogib1's Avatar
motogib1
Just out of curiosity, is that an 02 Z06? Didn't say in your profile. I understand the may have had a bad batch of valve springs produced in 02. There have been a few reported here on CF.
Old Mar 31, 2008 | 11:30 PM
spicytuna's Avatar
spicytuna
Very nice!!!
I'm glad that your horror story ended with a happy ending. Let us know how it rides after you get it back.
Old Apr 1, 2008 | 12:59 AM
Numb's Avatar
Numb
Yep, it is an 02 Z06. Didn't know it was a trend for that year, but LG said they have piles of broken stock C5Z06 valve springs.
I finished flycutting the pistons tonight... a little scary at first gouging up the pistons in your perfectly good shortblock, but they turned out fine. Heads go to the machine shop tomorrow to get milled.
Old Apr 1, 2008 | 09:45 AM
  #33
jovette's Avatar
jovette
How do you flycut the pistons and ensure that the weight / balance is the same for all 8?
Old Apr 1, 2008 | 08:43 PM
  #34
Numb's Avatar
Numb
Not 100% sure, but you're cutting each piston at TDC with the same tool, from the same angle, and to the same depth (.080). I measured the resulting cuts with a caliper, and they are all identical in size and shape. "Close enough" is the phrase that comes to mind.
Here's another question... At LG's recommendation, I had the head milled to 59cc and am going to use a .040 Cometic gasket. To reduce the chambers to 59cc, .036 had to be removed from the surface of the head... fairly significant numbers. But with all that change, they sold me stock length Comp 7.400 pushrods... wouldn't I need a shorter pushrod to offset the extra preload that milling the head and going to a thinner gasket will create? Doesn't make sense to me.
Old Apr 3, 2008 | 03:10 PM
  #35
Billdog350's Avatar
Billdog350
I could understand a spring failure at high rpm on a missed shift, but I was just cruising along in 6th gear at 70mph. WTF?!
Granted I had aftermarket gold dual springs and a G5X1 equivalent "generic" cam..but I had the exact same thing happen to me!
I started planning on tearing down the motor and everything else, but common sense took hold. I put a spark plug adapter in that cylinder and checked if the cylinder would hold pressure when I put compressed air on it. If your piston has a hole, the valve seat is broken, or the valve is bent , you'll hear air rushing out either into your intake, bottom end, or exhaust.
I lucked out, my valve (new stainless valves from PRC), and piston were fine. I just installed a fresh valve guide seal (the old one was destroyed) and a new spring and I was good to go. I also checked the hardened pushrod for any micro cracks or bending...it was fine also. I've put another 5k mi on the car since the spring replacement with no issues. If you need a new valve guide seal, PM me, I can mail it to you so you don't need to buy a whole new set of 8 form gmparts house like I did.
Old Apr 3, 2008 | 05:09 PM
  #36
BUGZ's Avatar
BUGZ
Always like a happy ending.
Old Apr 3, 2008 | 06:54 PM
  #37
Numb's Avatar
Numb
Thought I'd update this thread with some pictures from the teardown...
On my friend's lift
Broken valve spring
Same broken spring
Dirty, but not a scratch on it
Closeup of the valve
Tranny pulled (the reason I was going to Dallas in the first place)
Motor pulled
Just prior to destroying the balancer while trying to remove it. Motor looks like it came out of a 4x4!
Flycutting the pistons
LG G6X3 V2
LG Pros
Current status: a shell of its former self.
I'll add more pics as it starts going back together.
To Road trip cut short
Old Apr 3, 2008 | 07:07 PM
  #38
CamaroAJ's Avatar
CamaroAJ
Pro Mechanic
Pro Mechanic
you got luckey. 2007 Z06 with 2880 miles, 25mph in town. broken valve spring just like yours.
http://i25.photobucket.com/albums/c8...asonZ06006.jpg
http://i25.photobucket.com/albums/c8...asonZ06005.jpg
http://i25.photobucket.com/albums/c8...asonZ06004.jpg
http://i25.photobucket.com/albums/c8...asonZ06003.jpg
http://i25.photobucket.com/albums/c8...asonZ06002.jpg
http://i25.photobucket.com/albums/c8...onZ06001-1.jpg
good thing i planed on putting new valve springs in my car before the autocross in 2 weeks.
Old Apr 3, 2008 | 07:21 PM
  #39
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Warranty?????????????????????????? Or did you mod it and there was no coverage? Man that sux.
BC
Originally Posted by CamaroAJ
Old Apr 3, 2008 | 08:11 PM
  #40
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You sure do work fast.
