Dash Lights
Old Mar 31, 2008 | 10:06 AM
SSWEET's Avatar
SSWEET
Default Dash Lights
So Saturday I took the car for a little spin...first time out of winter hibernation...it stays on a battery tender all winter. As it turned to dusk I noticed no dash or radio console lights. I thought maybe I had somehow turned the dimmer ****...but that didn't change anything. Pulling back into my driveway, there is a sight bump at one of concrete seams.....bingo...the dash lit up like a Christmas Tree...which leads me to believe a loose wire...maybe ground....anyone know which ground I should check? Any help would be appreciated....
Old Mar 31, 2008 | 10:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There has been a rash of this problem and most of the times it is the light control stalk on the steering column. The contacts inside the switch get weak and no-longer make good contact. If it happens again see if banging on the steering column and or turning the driving lights ON & OFF a few times changes the symptoms. If it does, there is an assume write up on repairing the switch for FREE!
Bill
Old Mar 31, 2008 | 01:25 PM
SSWEET's Avatar
SSWEET
Thanks Bill
To Dash Lights
