If you have an 02-04 check and right above the headers on the head you should see a bolt hole, actually you should see 4 bolt holes. See if your bolt matches and threads into the last or 3rd hole. If it does then put your dipstick in and line up the bracket to the head. Mine went into the 4th hole and everything lined up perfectly. I have LG streets, but believe you are having the same problem.
all 241 head castings are the same no difference on 02-04
I took some pics to for ya, going to upload and post in one sec
