valve train setup
Old Apr 2, 2008 | 12:59 PM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default valve train setup
anyone runing with patriot 650. lift valve springs and yella terra ultralight 1.8 rockers, 01 z06 stock cam, would like to know what size push rods you are using. thanks
Old Apr 3, 2008 | 01:33 AM
Last C5's Avatar
Last C5
I'm running PAC 1518 springs which have a .650 lift capacity with the Yella Terra 1.8s on a stock cam 01 Z06 and I'm using 7.4 High tech Comp push rods.
Old Apr 3, 2008 | 10:05 AM
vettenuts's Avatar
vettenuts
Did you check wipe, and if so did you shim the rockers?
Old Apr 4, 2008 | 01:42 AM
Last C5's Avatar
Last C5
I checked the wipe first with the shims and it was way off. When I removed the shims it was right on and it preloaded right to spec during the install.
To valve train setup
