Hood Seal
Old Apr 5, 2008 | 08:08 AM
garye904's Avatar
garye904
Default Hood Seal
Any information out thee on hood seal? How does it help, who sells them, and installation?
Old Apr 5, 2008 | 09:53 AM
AJay's Avatar
AJay
No performance boost if thats what your asking.
Old Apr 5, 2008 | 10:05 AM
MKeller's Avatar
MKeller
GM didn't seal the hood at the end just on the side's. If you go to an aftermarket intake like the blackwing water can run down the hood getting it wet. Wet air cleaner = not good.
As far as performance it don't do anything but add 10 hp.
Old Apr 5, 2008 | 10:07 AM
clif's Avatar
clif
St. Jude Donor '09-'10
the hood seal is great, to keep dust and dirt off the engine. Thats why I put one on.
Old Apr 5, 2008 | 10:31 AM
robert123's Avatar
robert123
great bang for the buck!
Old Apr 5, 2008 | 01:23 PM
dndrsn's Avatar
dndrsn
Keeps dust, dirt, water, and cooler air out of your enginebay.
Old Apr 5, 2008 | 08:38 PM
RA91925's Avatar
RA91925
Mid-America sells them. I bought one while at the Funfest in September. It is sitting here next to the computer as a reminder that it hasn't been installed. Installation is one of those "peel off the backing and stick it into place" operations. Removal would be a bigger pain.
Not sure that I am going to bother to install it. Maybe others will convince us that it is something of value to install.
Old Apr 5, 2008 | 08:42 PM
MagRedConv's Avatar
MagRedConv
That's funny. I bought one seven years ago when I upgraded from the C4. I installed it this past wednesday after modding the airbox cover!
Old Apr 6, 2008 | 02:18 AM
tmqdoc1's Avatar
tmqdoc1
Just installed mine today. I bought it from Southern Car Parts. It was a breeze to install and appears to be a quality piece. Functionally for keeping engine bay clean and dry.
Chris.
Old Apr 6, 2008 | 09:23 AM
rws.1's Avatar
rws.1
makes your own...
go to Lowes or Home Depot and buy some household window seal, or go to an autoparts store and buy some EPDM weatherstipping
Old Apr 6, 2008 | 11:25 AM
C5XTASY's Avatar
C5XTASY
If it's like mine was, you will discover that removal is very easy. As a matter of fact, it "self-removed". I ended up using 3M double sided tape to secure it. No problems since. As mentioned earlier, it's good for keeping water off a Blackwing. That's why I have one.
Ed
Old Apr 6, 2008 | 11:30 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by rws.1
makes your own...
This is what I did following someones advice in a thread. There is enough to do about 2 vettes for around $10.
Old Apr 6, 2008 | 06:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
makes your own...
I did the same, I made 2 seals. I paid it forward on the 2nd
Old Apr 6, 2008 | 06:31 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
makes your own...
I think I'll give this a whirl. What do you use to stick it down with?
Old Apr 6, 2008 | 07:26 PM
screw991le's Avatar
screw991le
It is peal and stick, just clean the area with rubbing alcohol before you stick it on the car.
Old Apr 7, 2008 | 01:15 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
It's the same gasket used on the deck lid of the coupe. One drawback is if you have a bra the gasket is in the way. My engine compartment still gets sandy and I have a Vararam so I get no benefit. Waste of $10. (or more) in my opinion.
Old Apr 7, 2008 | 08:55 AM
Gordy M's Avatar
Gordy M
The hood seal is very good if you want your engine bay to have more heat. While you keep dust out you also keep the heat in. If anything it will only cost you about 5 hp.
To Hood Seal
Old Apr 7, 2008 | 10:41 AM
jovette's Avatar
jovette
Probably doesn't cost any HP, if you have CAI. I'd be interested in seeing your dyno results that document a scientific experiment that shows the hood seal results in a 5 hp loss, as you claim.
Old Apr 7, 2008 | 01:25 PM
T VETTE's Avatar
T VETTE
I doubt it makes any measurable difference either way on air temp or HP. It will keep out dust and rain water for sure.
If you really want to move some hot engine compartment air, change out the fog lamp surround covers to vented style or drill them out and or put on Z 06 screens.
Old Apr 7, 2008 | 04:08 PM
SinghZvette's Avatar
SinghZvette
Not only does the hood seal keep the dirt out but after washing the car, not a drop of water near that area. Go for it.
