6th Gear Performance Issue
Old Apr 11, 2008 | 02:57 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Default 6th Gear Performance Issue
It use to be that in 6th gear, I had good throttle response and power once doing 75mph and above. Lately, what I feel is about 1/2 throttle, it responds this same way nicely but pushing farther on the throttle, it accelerates slowly almost like the old days when an engine would be running too rich or too lean.
I replaced the front O2 sensors yesterday which made no change. I'm considering going out there right now and plugging the pcv to intake connection and see if it improves. No codes are present. I'm still on the original fuel pump so maybe its getting weak but I have no fuel pressure meter to connect. If the cats were partially plugged, I would think anything blocking the inlet screens to them would be burned out real fast. Yes, air filter is clean and I cleaned the maf again too.
Looking for thoughts.
Old Apr 11, 2008 | 03:04 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I think you are missing something here... we designed the MN6 with two overdrive gears: 5th and 6th, these were never meant for power or performance.. so dont look for them.. both gears are less than 1:1 and were put there specifically to get you that 32/33 mpg. If you had a problem with your car, the car would tell you so... So dont look for problems that arn't there... if you notice some slugishness, chalk it up to less dense warmer air now that spring is here.. and it's more noticable in 5th and 6th gear.
Old Apr 11, 2008 | 03:09 PM
dgrant3830's Avatar
dgrant3830
No, this is the car with currently 308K on the clock and up until the past couple of months, the performance that I speak of was there. I'm the only owner of this car. It seems that mileage dropped off a little as well. Of course I never expect it to blast off down the road in 5th or 6th gear but I know a loss of performance when I feel it.
Old Apr 11, 2008 | 08:57 PM
Tom Porter's Avatar
Tom Porter
How does it runs 1st through 4th?
Old Apr 11, 2008 | 11:10 PM
dgrant3830's Avatar
dgrant3830
1st through 4th are fine but its hard to tell. I did do something today that has made a difference. I got into the computer, downloaded the PCM using LS1Edit and found the Main and Sec VE Fuel tables had errors in them as well as the High and Low Octane spark tables. I fixed all of them, uploaded the changes then drove it. Feels better. I'll know after about a week of driving it, if it really made a difference or not.
Old Apr 12, 2008 | 04:51 PM
Tom Porter's Avatar
Tom Porter
I hope that worked.
To 6th Gear Performance Issue
