Head bolt hole cleaning
Old Apr 18, 2008 | 12:09 AM
thetorch's Avatar
thetorch
Originally Posted by verano29
I assume one of these is for the "big" holes on the bottom and the other for the "little" holes on top?
Where should I order these from?
M11 x 2.0 are the large holes
M8 x 1.25 are the small holes
I purchased from Summit Racing, but anyone that carries ARP can most likely get them for you.
Old Apr 19, 2008 | 02:03 AM
verano29's Avatar
verano29
Originally Posted by ArKay99
If you want, PM me your address and I'll grind flutes in a couple of old head bolts I have and send them to you.
Thanks for the offer! I actually just did that myself.
Old Apr 19, 2008 | 07:55 AM
vettenuts's Avatar
vettenuts
Originally Posted by thetorch
You won't find a thread chaser for the large head bolts anywhere except ARP or Kent Moore. I own and have used both the ARP and Kent Moore thread chasers. IMHO, the only way to clean head bolt holes. These are NOT taps.
They are expensive but work very well, here's the ARP part numbers:
912-0001 Clean Out Tap M8 x 1.25
912-0011 Clean Out Tap, LS1 M11 x 2.0
Aaron,
Great information. Since my installation is now on hold, I may just get a set of these
Old Jul 30, 2014 | 01:01 AM
akajoseph's Avatar
akajoseph
1st Gear
there is a seller on ebay that sells a thread cleaner for the ls engine head bolt threads. it must work -- all his feedback is 100% positive --- then sellers name is akasandjoe
Old Jul 30, 2014 | 01:22 AM
Tech's Avatar
Tech
Ban this guy please.
Old Jul 30, 2014 | 01:34 AM
onspeed's Avatar
onspeed
Grind two slots into the old bolt, screw in and out until gunk stops accumulating in the gap, then some carb cleaner and ample compressed air to finish it off.
Old Jul 30, 2014 | 09:26 AM
taken19's Avatar
taken19
Track Junky
As others have said, start with compressed air for the majority of the liquid. Then grind down an old head bolt on 2 sides. Run that bolt down into the hole several times until the grime/debris does not appear on the bolt.
Remember to grind down one of EACH size head bolt - the large one and small one. They are free and may help out a friend in the future as well. I still have mine from years ago...
