Cleaning C-5 engine
Old Dec 13, 2001 | 05:25 PM
Jerryk's Avatar
Jerryk
Default Cleaning C-5 engine
I have a 1998 used C-5 A-4 the engine needs cleaning its not bad but not to a point i want. Should i use a engine cleaner, or maybe just hot water and soap. Thanks jerryk :smash:
Old Dec 13, 2001 | 05:29 PM
MitchellDavidson's Avatar
MitchellDavidson
Default Re: Cleaning C-5 engine (Jerryk)
I am intersted in this as well. I think it should go in car care though. :yesnod:
Old Dec 13, 2001 | 05:45 PM
C5Noir's Avatar
C5Noir
Default Re: Cleaning C-5 engine (MitchellDavidson)
This is the best way I have found:
With your engine cold drench it with Simple Green Cleaner. Let it sit for about 10 minutes and then blast it off with a garden hose. Then use a leaf blower to blow it dry. (if it is soiled with dirt use a rag to wipe down the engine bay with Simple Green before rinsing :D). Then spray some Armor All on a cloth and wipe down the plastic areas. Makes it VERY nice looking. If you want it to REALLY shine (but it'll be VERY greasy) drench the plastic areas with Armor All and let it sit overnight and wipe off the excess in the morning :D. But Simple Green is by far and away the best I have used to date.
Old Dec 13, 2001 | 05:54 PM
silversport's Avatar
silversport
Default Re: Cleaning C-5 engine (C5Noir)
I second the simple green and it is great for cleaning wheels and tires with no worries bout etching the wheels.
Old Dec 13, 2001 | 06:34 PM
Rick-M's Avatar
Rick-M
I use the simple green solution describe by C5Noir and it works great, to date no problems. Think it's important to make sure the engine in not hot and to dry it off after cleaning.
Old Dec 13, 2001 | 09:51 PM
ace's Avatar
ace
Is everyone using 100% SimpleGreen or are you diluting it with water? If so what percentage of each? Thanks.... :cheers:
Old Dec 13, 2001 | 09:57 PM
ZAP's Avatar
ZAP
Default Re: Cleaning C-5 engine (ace)
I use 100% :cheers:
Old Dec 13, 2001 | 10:17 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Cleaning C-5 engine (ZAP)
I take mine to a do it yourself car wash, I wash the engine with high pressure soap followed by wax then high pressure rinse.
then spray the engine with no touch and wipe off the excess.
never had any problems from this procedure. just don't drench the air filter and it will be ok. :cheers:
Old Dec 14, 2001 | 08:33 AM
Lil Red's Avatar
Lil Red
Default Re: Cleaning C-5 engine (RPOZ4Z)
I take mine to the coin wash as well. It does a fine job and only takes 5 minutes. Wash with high pressure soap, rinse with wax and then clear water. The wax helps to keep the grease from sticking and staining the motor. It makes the next wash even easier! :cheers:
Old Dec 14, 2001 | 12:55 PM
jefffxdwg's Avatar
jefffxdwg
Simple Green 100% and it works great on the Harley too.
Old Dec 14, 2001 | 01:20 PM
Net Exploit's Avatar
Net Exploit
Default Re: Cleaning C-5 engine (jefffxdwg)
Simple Green on for about 10 minutes and then pressure wash, followed by
a leaf blower and air compressor where necessary.
Old Dec 14, 2001 | 01:26 PM
carpe dm's Avatar
carpe dm
Simple Green is good, but I have found that the ZEP orange cleaner from Home Depot used as a 50/50 water solution does a better job and cleans up well. Spray it on, wait a few minutes and gently spray it off with the hose. Towel dry or use a shop vac/leaf blower to get rid of the water. Follow with a good detailer. Enjoy.... :)
Old Dec 14, 2001 | 03:01 PM
New-B's Avatar
New-B
Default Re: Cleaning C-5 engine (carpe dm)
Thats what I used (Zep)...................
Old Dec 14, 2001 | 05:03 PM
bean0820's Avatar
bean0820
What do you do about the unpainted pieces (i.e. alternator MAF housing). Mine are starting to look a little weathered.
To Cleaning C-5 engine
