Old Apr 17, 2008 | 06:27 PM
z06 vett's Avatar
z06 vett
Default ???????????????
i just got my rpm motors hptuned pcm back and stuck it in.the cats have blown there guts out and it backfires.the lm-1 says 1.63 lamda 39 afr or so.13afr after backfire.i can smell gas(55psi on rail) but as it gets hot the garage filled with smoke from the cats.had to get out.this is my first time with injected motors.never mind twin turbo.so my vacuum gage and timming light are out.it does not sound as if there is an exhaust leak????any help out there.mike in mobile
Old Apr 17, 2008 | 06:40 PM
AU N EGL's Avatar
AU N EGL
Time to get your car to a real tuner. With all those mods a mail order tune is not going to do it for you.
Old Apr 17, 2008 | 06:54 PM
c5_4_me's Avatar
c5_4_me
Old Apr 17, 2008 | 07:29 PM
NASAblue's Avatar
NASAblue
well at least you wont have to hollow out your cats and you'll gain a a good 10 or 20 hp from that.
Just tell you tuner to delete the rear 02's and leave it set to pass emissions.
congrats on the extra ponies, it'll all work out
Old Apr 17, 2008 | 07:34 PM
NASAblue's Avatar
NASAblue
have you tried the forced induction forum over on ls1tech?
http://www.ls1tech.com/forums/forumdisplay.php?f=9
best of luck
Old Apr 18, 2008 | 01:03 PM
z06 vett's Avatar
z06 vett
Default tuner in mobile?
i wish,there are two guys in mobile with hp tuners and i have tried very hard to talk to them.its like they do not want the business.i think i just sold the diablo.looks like it is the next step and buy the hp pro.we have 93 octane gas with no emissions here.street racing and cruising are also big.
thanks guys, mike in mobile
Old Apr 19, 2008 | 08:39 PM
z06 vett's Avatar
z06 vett
Default tried all
i calibrated the lm-1 in air,started up ok and then got worse as it warmed up.3.3 lamda.center pipe off at intercooler had the same thing.the stange thing is the left bank seems to be the problem.the right side does not backfire and has the normal water at the exhaust pipe.mike
Old Apr 24, 2008 | 04:36 PM
z06 vett's Avatar
z06 vett
Default oops
a new one for the books i fliped the coil harness 1 for 8.runs
Old Apr 24, 2008 | 11:47 PM
jedblanks's Avatar
jedblanks
can you explain that a little better? So others can understand what you did and not make the same mistake?
Are you saying the driver's side coil harness was upside down, so 8 was going to 1 and 1 was going to 8?
Old Apr 25, 2008 | 12:26 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Heck, that doesn't even make any sense. The evens and odds are on different harnesses and opposite sides of the motor, so I don't know what the heck he is saying. Maybe a connection somewhere else was flipped or reversed.
Old Apr 29, 2008 | 03:39 AM
z06 vett's Avatar
z06 vett
Default not much of a wrighter
when my friend took the coil pack off, to cut clearance for the fuel line. he put the #1/8 yellow tag on #8 instead of 1 of 8.it was like wiring a distributor cap wrong but real hard to see.hope that clears it up.i am still not ruining right yet.the cooling sys. has been a bitch.i burned up no. 2 wire today,too close to header..tomarrow is my fifth try at the cooling.mike in mobile.
To ???????????????
