Need Help. Rear wiring
Old Apr 17, 2008 | 08:13 PM
foggy's Avatar
foggy
Default Need Help. Rear wiring
I am in process of repainted my 00 Vert.
Rear bumper is off , replaced/painted and ready to go back
on but I have a mysterious wire.
It is up high on rear body with 3 metal clips. the black wire
then goes toward elect antenna where I think it grounds,
then proceeds over Right Rear fender well and "ends"
up high in wheel well but does not "go" anywhere that I can
find
It has a delphi barcode and date sticker on it.
Can't even find part at dealer to identify it.
Please help. Body shop want to reassemble tomorrow.
Old Apr 17, 2008 | 09:51 PM
byronhunter's Avatar
byronhunter
Default ant wire
ground plane wires for ant, not supposed to be attached at ends!
Old Apr 17, 2008 | 10:18 PM
foggy's Avatar
foggy
does it connect to antenna in middle, looks like "loop" is broken off.
What the heck is its purpose??
Thank You
Old Apr 17, 2008 | 10:50 PM
c5streak's Avatar
c5streak
Old Apr 17, 2008 | 10:56 PM
foggy's Avatar
foggy
OK, I understand its purpose.
Neither end is connected. It's just there to provide a 'reference'
for the radio signals
Question still: Right by the Delphi bacode sticker with build date, there is a "junction" .. Is there supposed to be a metal loop there so it can attach to annenta?
Old Apr 17, 2008 | 11:03 PM
byronhunter
Default ant wire
Foggy, Center of leads attach to metal of ant base, ends do not attach to anything. HTH
Old Apr 17, 2008 | 11:13 PM
foggy's Avatar
foggy
Perfect.. Just freakin confused as to what the heck this even is..
Want to get bumper put back on tomorrow.
I will make a metal "loop" to attach middle that is broken to
antenna. Then the 2 ends will just be remounted as is..
Kinda like my old home stereo's FM antenna I had college!!
To Need Help. Rear wiring
