Interior Light Flicker
Old Apr 19, 2008 | 03:59 PM
pscharfg's Avatar
pscharfg
Cruising
Default Interior Light Flicker
Hi. I went to start up my 1999 C5 a few weeks ago at night and the headlights came on, but did not raise. I manually turned the headlamp switch on and that made no difference. I shut the car off, removed the key and then started her up again. The headlights came on and raised. However, as I was driving I noticed that all of the dash lights flicker. The problem has occurred several times but is intermittant. Any ideas?
Thanks in advance.
Old Apr 21, 2008 | 01:44 PM
pscharfg's Avatar
pscharfg
Cruising
Does anyoine know if the interior lights and headlamps work out of the same wiring harness or junction?
Old Apr 21, 2008 | 09:10 PM
minitech's Avatar
minitech
The first thing I would do is look at the battery termianls. Remove them and replace securely. That could easily be the problem and a good place to start.
To Interior Light Flicker
