LS1 Engine weight - Auto Vs. Manual
Old Dec 14, 2001 | 12:29 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default LS1 Engine weight - Auto Vs. Manual
I pulled this info off the Spec sheet from the chevrolet website......
Total Dressed Engine Mass (wt.) Dry Automatic 457.6 lbs. (208 kg); Manual 497.2 lbs. (226 kg)
Can anyone explain why the LS1 in an auto car weighs 40 lbs less than a manual.....
thanks
zack
Old Dec 14, 2001 | 12:54 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: LS1 Engine weight - Auto Vs. Manual (y2k02c5)
They must be including the clutch assembly on the dressed motor weight.
Old Dec 14, 2001 | 01:00 PM
Road Warrior's Avatar
Road Warrior
CI 3, 4, 5, 6 & 10 Veteran
Default Re: LS1 Engine weight - Auto Vs. Manual (kewlbrz)
That would be my guess too.
Mike
To LS1 Engine weight - Auto Vs. Manual
