How hard to remove the radiator?
Old Apr 23, 2008 | 07:58 AM
1sickz51vette's Avatar
1sickz51vette
Default How hard to remove the radiator?
Hey guys, my radiator developed a leak and I was thinking about pulling it out and taking it down to the shop. How hard is this to do? Are there any instructions I need, or is it pretty simple? Thanks for the info!
Old Apr 23, 2008 | 08:15 AM
vettenuts's Avatar
vettenuts
In a nutshell: Drain and remove hoses. Need to remove intake setup and then upper radiator support. Need to remove the air dam in front of the condenser, then unplug the fans (left side plug is a pain), then remove fans by rotating and lifting out. Uncouple condenser from radiator clips and then it should come out. Its not a bad job at all. An extra set of hands for lifting is helpful but I have done it alone too.
Old Apr 23, 2008 | 10:35 AM
1sickz51vette
thanks so much for the info!
Old Apr 23, 2008 | 11:12 AM
RoccoC5's Avatar
RoccoC5
Those fan plugs were such a pain when I pulled my radiator a couple of weeks ago that I just left the fans in the car. I removed them from the radiator (they "snapped" onto the radiator in my 2000, no fasteners). Made clearance a bit tight when removing/installing the radiator, but not too bad.
Old Jun 18, 2008 | 06:03 PM
1sickz51vette
Well its time to get the work done, but I'm not sure where to start with the upper radiator support? I think im gonna have a buddy try to give me a hand with this...
Old Jun 27, 2008 | 07:15 PM
Chicago1's Avatar
Chicago1
^ You talking about the shroud? Look at the end of the shroud you will see 2 10mm bolts on each side. Take those 4 out and she pops right out.
Old Jun 27, 2008 | 10:02 PM
enos44's Avatar
enos44
yea I took mine out the other day and didn't remove the fans or air damn and an extra set of hands is very helpful, I also had the front of the car on jackstands. Goodluck
Old Jun 27, 2008 | 10:32 PM
thetaxman's Avatar
thetaxman
as long as it's out
get an aftermarket one
To How hard to remove the radiator?
