FYI: Harmonic Balancer Troubles (pics)
Firestone calls me up later on saying they think my whole crankshaft moved forward an inch. I'm thinking if that happened I'd be looking for a new engine because I wasn't sure how that could happen and still have driven it to work. I called up the guys at L.A.P.D.. I would have brought it to them in the first place but I work the opposite way from where I live and where LAPD is located. Keith at LAPD had an idea on what it was and was pretty much right on with it. So I had to have it towed there because it wasn't safe to drive it that distance.
So what they found was that the harmonic balancer pulley had actually broken and the middle separated from the outer part and pulled away by a 1/4 of an inch. That was just enough for it to hit the front cover and throw off the belts and whatever else. They said they have never seen that particular problem with the harmonic balancer but have known them to go bad in other ways before. Luckily they had a good used one in the shop and had me on my way in no time.
Here are some photos just for CF's knowledge in case this happens to anyone else.
This is what a stock one should look like:
Here is what mine looked like. You can see the middle portion separated and pulled out of the outer part. It should be flush like you see in the first picture.
Here's an inside view of my pulley:
I don't know if anyone else has had this problem but does anyone know if this is common or how/why this would happen? I drive a bit hard or as I like to call it free spirited but I have never seen this happen before. I read a little bit about harmonic balancer problems but didn't see too much info.
-Shawn
And people wonder why "repair shops" get such bad reputations.
Good to hear L.A.P.D. is taking care of your situation.
That has to be the most idiotic thing I have heard in a long time
. I would have started laughing uncontrollably in their faces
right before I told them to f*$k off!
Yeah, I don't know much of the heavy technical stuff but I do know if a crankshaft moved that it would be a bigger problem then what I was experiencing. I trusted them in the past for brakes and tires and stuff, but I got the vette and know they don't really do much with them. I figured though this seemed like something anyone who calls them self a "mechanic" can probably figure out, I guess not.
Thanks L.A.P.D.!!! I got a couple more things they are doing in a week or so. This was my second time dealing with them and they went out of their way to come to the shop after hours for me to pick up my car and go over some stuff. Really a top notch place.
Glad you got fixed. Mine slid back and took out the front engine cover, seal and oil pan. I went ahead and replaced the oil and timing chain and did a cam and spring install. Lot of work but saved lots of money and enjoyed doing it myself.
I will take a couple of pictures of the seal and hub tonight.
A new Power bond damper took care of that issue!
BC
Yeah, they told me it looked like it moved an inch. I think they were looking at the belt which must have been way off too. It was funny cause they called me to tell me what they found and were at least honest in saying they didn't know much about this situation and if I had a shop I worked with this car in the past that they might be more equipped to figure out the problem. I quickly agreed of course and that's when I called LAPD and told the first place to not do any more work on it. I had AAA come with flatbed and take my baby away from those crazies.
I guess there's an after market harmonic balancer but that would have cost me $400+ in just the part and they already had a used one they gave me for $50 so I just took the used one for now.
http://forums.corvetteforum.com/show....php?t=1872301
The harmonic balancer is a fairly common problem on C5s. Because of a previous post I read here on this issue a year ago, I had the local dealership check mine last May. Sure enough it was wobbling at 30,000 easy-driven miles. Even though I had no symptoms, when the Service Manager saw what was going on (just looking under the hood) - he said to leave the car and they would replace it under warranty. Unfortunately that meant another "stock" harmonic balancer... so I figure my days are numbered. No other balancer problems so far, but sadly when they dropped the steering rack to change it out, they somehow screwed that up. They are now replacing the steering rack for the 3rd time next week.
I have had quite a few Corvettes in the past that I put over 100,000 miles on and I never had a Harmonic Balancer problem in my life - so these are just defective IMO.
