Dissapointment Cont'd
Old Apr 24, 2008 | 06:02 AM
tiki240's Avatar
tiki240
Default Dissapointment Cont'd
Here is the dyno graph from when Edmcat tuned my 97... here are the mods list.
-TSP 1-3/4" headers
-3" high flow cats
-LS7 flywheel/clutch/pp
-TSP 233/239 cam
-25% UD pulley
-VaraRam intake
Im looking for more power obviously.. but its not just that.. ive seen dynos of other cars and ridden in a few with smaller cams that "felt" faster. i think TSP advertises that my power starts coming in around 2600 rpms from the cam and i guess i kinda miss that "nitro kick in" feeling from the 224 cams. anyways, im looking to feel like the car just keeps pulling harder and harder. but as you can see she runs outta power up top. like ed said, when he let off you can already see that the power was on the decline. my question is, will stg 2 heads and an ls6 intake mani give me a powerband that exceeds my rpm limitations? coming from a history of forced induction im used to pulling HARD all the way to the top as if if there were no redline it would keep pulling harder. so... now that i think ive singled out the "feeling" im looking for... what are the suggestions for power without going F/I?
p.s. Graph to follow.
Old Apr 24, 2008 | 06:10 AM
tiki240's Avatar
tiki240
Old Apr 24, 2008 | 07:00 AM
vettenuts's Avatar
vettenuts
Not sure what the link is, you have to be a member to see it.
The LS7 clutch setup will show less power, but if you are still running the LS1 intake, I would start there then move to heads. Did you degree the cam?
Old Apr 24, 2008 | 07:02 AM
tiki240's Avatar
tiki240
yeah we degreed the cam. do you have an email? my work filters block out all the imagehosting websites.. wanna do a guy a favor and host my graph for me?
Old Apr 24, 2008 | 07:10 AM
tiki240's Avatar
tiki240
or anyone for that matter
Old Apr 24, 2008 | 11:47 AM
WKMCD's Avatar
WKMCD
That cam with the LS6 manifold - or even better a 90/90 setup - and heads should kick you in the a$$ at 4k and pull hard to about 6600. It will probably still peak at about 6300 but drop off gently. The LS7 clutch is heavy but I still made 460 with a 230-236 112 90/90 PRC 2.5R 5.3 heads with the LS7 clutch.
There are some good deals on heads and LS6 intakes around here. Keep an eye out for those.
BTW: Ed's pretty damn good getting the max safe RWHP out of these engines.
Old Apr 24, 2008 | 12:10 PM
vettenuts's Avatar
vettenuts
Tried to PM my e-mail, your inbox is full.
Old Apr 24, 2008 | 03:09 PM
edcmat-l1's Avatar
edcmat-l1
Ask and yee shall recieve.
Old Apr 24, 2008 | 03:10 PM
edcmat-l1's Avatar
edcmat-l1
BTW, get the pushrod length figured out and you're bound to make a little chunk of power.
Old Apr 24, 2008 | 03:38 PM
tiki240's Avatar
tiki240
thanks ed <3
Old Apr 24, 2008 | 03:59 PM
99C5JA1's Avatar
99C5JA1
This an M6 or A4? I made 373rwhp with a TR 227/224 cam and headers. If it's an M6 I'd say you're down a little. If it's an A4 I'd say the numbers are pretty good.
Old Apr 24, 2008 | 04:14 PM
tiki240's Avatar
tiki240
car is a MN6.. i have the craptastic stock 97 LS1 heads which is more than likely one of many reasons im down on power. Any idea what length pushrods i should be running? i have 7.4 (factory length) hardened ones in there now. ed and i both agree that she is excessively loud. cam specs for inquiring minds is 233/239 .595/.603
Old Apr 24, 2008 | 04:18 PM
edcmat-l1's Avatar
edcmat-l1
Best thing to do is check the pre-load. Next best thing is throw some 7.450s in it.
I recommend checking the pre-load.
Old Apr 24, 2008 | 04:26 PM
foff667's Avatar
0foff667
Former Vendor
Yeah the stock heads & LS1 intake definitely are not helping you at all, Ed definitely knows what he's doing behind the keyboard so if theres power to be found he would be the one to find it.
-Bill
Old Apr 24, 2008 | 04:31 PM
Casem1's Avatar
Casem1
If I could find my pushrod length checker I would mail it to you so you could use it. Whereever it is, it is only collecting dust...
That cam seems way big for stock untouched heads.
I am at work and the pics are always blocked so I can't see a graph and have no idea what numbers we are talking about. One thing I have learned in my 4 years with this car is that I would do it all again but in a completely different way... I would spend mad $$$ on good heads and base the rest on that.
Old Apr 24, 2008 | 07:07 PM
vettenuts's Avatar
vettenuts
That's what I am doing as well.
Old Apr 24, 2008 | 08:45 PM
vetpet's Avatar
vetpet
You need to match the cam and heads if you want to achieve max power. You're way overcammed for the heads you have. A good set of heads and a better intake and you'll probably get at least another 45 to 55 hp. I'm running a small cam (212/218) with ported LS6 heads and LS6 intake and made 360rwhp/356ftlbs on the dyno so you will certainly make some good gains with good heads & intake. A good cold air induction system will make will also help a lot as this is one of the areas where the OE induction system is very weak.
To Dissapointment Cont'd
Old Apr 24, 2008 | 09:03 PM
WKMCD's Avatar
WKMCD
The heads/intake are definitely not keeping up with that cam. Those heads probably won't effectively support more than a 224 size - or less - cam. You can see where the cam tries to come on at 4k but just can't.
Good news is, now you know what the next step is.
Old Apr 28, 2008 | 01:29 PM
Boob's Avatar
Boob
Double hump tq curve indicates you need more intake airflow.
Old Apr 28, 2008 | 01:44 PM
chaase's Avatar
chaase
St. Jude Donor '12
You are in serious need of heads and an LS6 intake. That is not exactly a small cam, and you are starving it of air.
