I just (tonight ) finished installing a POWERBOND under drive damper. I installed a pinning kit and used an ARP Bolt to install it. Its a QUALITY piece! Unless your going to spent=d the extra dollars for an ATI rattler or one of the other active dampers,,,,POWERBOND is an outstanding damper. Its already got a key way machined in the hub for a pin!
I heated the hub with a heat gun to 140-150 deg and used an install tool to press it on. Went right on!!
