Let's Play How Does That Part Get Put Back Together..
Old Apr 26, 2008 | 04:08 PM
thefritz1's Avatar
thefritz1
Default Let's Play How Does That Part Get Put Back Together..
I've got the brutal squeaks going on with my 02 z06. I replaced both belts and the drive belt idler and tensioners. BUT I have no idea which way the drive belt idler gets put back on the damn car. My careless *** never noticed. The first way I put it on the bolt starting backing out but I may not have snugged it down enough. Could y'all help me out by explaining orientation of the idler and the best way to snug it down correctly?
Pics for your reference....
or
Old Apr 26, 2008 | 07:37 PM
myk7's Avatar
myk7
The open side goes toward the engine. Not sure why the bolt would back out.. tighten it more
Old Apr 26, 2008 | 08:30 PM
motogib1's Avatar
motogib1
Use the correct torque specs, don't randomly overtorque it. For a little insurance against backing out, use a little blue locktite.
Old Apr 27, 2008 | 12:18 PM
c5streak's Avatar
c5streak
Manual says 37lbft for either idler or tensioner.
Old Apr 28, 2008 | 02:50 PM
thefritz1's Avatar
thefritz1
Can someone just confirm if the idler pulley (when tourqued to specs) should spin freely when the car is off. I haven't gotten to this install yet but just want to be sure that everything is seated correctly the idler pulley should spin freely. I wasn't sure.
Thanks!
Old Apr 28, 2008 | 03:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
With out a belt,, the pulley should spin freely when its installed!
To Let's Play How Does That Part Get Put Back Together..
