Anyone changed over to #30 injectors?
Ford SVO, RC Engineering, Accell, or other?
Have read about the Accells leaking, most are satisfied with the SVO's
Halltech is using the RC Engineering injectors, and I have not heard any feedback on them.
I would think it would be fine with the stock ones. It wouldn't hurt anything you could get auto tap and a MAFT and tune them and as you get more mods make adjustments, but I think you could find better ways of spending the $$$ JMHO
I have the SVO 30's and have had no problems. I used a MAFT and a Scan Ease program to tune in more advanced timing. Here is a link to a page by Kewlbrz that will explain: http://www.vetteguru.com/mods/howto/#injectors
I also installed them in anticipation of future modification.
Anyone know how much the Z06 injectors are? I have a 99 and MMS is building me a 388 (should be done in a few weeks). I would rather use an injector that looks stock and has a stock spray pattern.
Nervermind, just went to the site and it looks like the 97-98 injector is about the same size as the Z06. I can probably find a set of those cheap or just use the SVO.
