TRANSCO KIT
Old Dec 16, 2001 | 10:10 AM
ROD BROWN's Avatar
ROD BROWN
Default TRANSCO KIT
I am planning to install a transco kit in my 99 vette.Is this a wise decision or is there a better alternative?The installer told me ,he doesn't like to make them shift so hard they "bang" going into gear.pricedat $600 including the kit.6 hrs. to install. :chevy :flag :flag :chevy (stars and stripes forever)
Old Dec 16, 2001 | 10:25 AM
vstella's Avatar
vstella
Default Re: TRANSCO KIT (ROD BROWN)
:bs I don't know WHO you spoke with but that's NOT the case at all.
The Transgo kit installed is probably the best bang for the buck for A4's out there.The kit is a remarkable improvement in your shifts,especially if you have an aftermarket converter.
The shift kit costs about $109.00 and is available at several CF vendors. I got mine at www.theLAPD.com from Shawn.The kit has 3 settings-street,street/strip and race.The kit should be installed by a QUALIFIED transmission technician,not just anybody that hasn't installed one before.The install should cost $150-$200.
Search the C5 Tech Discussions for ALL the related psts on this subject for more info on this subject.MANY have installed this kit with great results.
Including me! :chevy
Old Dec 16, 2001 | 10:54 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: TRANSCO KIT (vstella)
I can't wait to install one in the near future. :jester
Old Dec 16, 2001 | 12:16 PM
oceanaire's Avatar
oceanaire
Well, the Transgo kit is fantastic. Mine doesn't "bang" into gear. It is a very fast, crisp shift. It'll plant you in the seat. $600.00 seems way too high. As stated above, $109.00 for the kit, and around $200.00 for the install.
Get it, you will not regret it! :yesnod: :D
Old Dec 16, 2001 | 10:03 PM
2000^C5's Avatar
2000^C5
Default Re: TRANSCO KIT (oceanaire)
Where did you get yours installed?
Old Dec 16, 2001 | 10:12 PM
oceanaire's Avatar
oceanaire
Default Re: TRANSCO KIT (2000^C5)
Had it done in Jupiter at a place called All Transmissions. The guy that runs the place, Billy Ray, is an old hot rodder. Well, not that old, he's about 5 years older than me. I keep forgetting I'm forty. He's done tons of the Transgo and B&M kits.
[Modified by oceanaire, 9:15 PM 12/16/2001]
Old Dec 17, 2001 | 09:45 AM
jeffh355's Avatar
jeffh355
Anybody have any recommendations to install this kit in the Los Angeles/Pasadena Calif area? I would really like to get one of these kits installed. Thanx Jeff
Old Dec 17, 2001 | 10:49 AM
2000^C5's Avatar
2000^C5
Cool, thanks!
Well 4 more days before you go to Mike, that will be awesome! Tell Mike that I say hi.
Doug
Old Dec 17, 2001 | 11:18 AM
oceanaire's Avatar
oceanaire
Cool, thanks!
Doug
I will, Doug. Eric
Old Dec 17, 2001 | 11:54 PM
C5 in 2002's Avatar
C5 in 2002
If I get this shift kit will I still need to go with the powerloader II to get the hesitation from between shifts to stop? :confused:
Old Dec 18, 2001 | 02:18 AM
bparker's Avatar
bparker
Default Re: TRANSCO KIT (C5 in 2002)
Transgo recommends that - YES - you "should" remove Torque Management via some sort of programming...
Old Dec 18, 2001 | 02:29 AM
C5 in 2002's Avatar
C5 in 2002
Default Re: TRANSCO KIT (bparker)
Thanks, I was afraid of that :mad I thought I might get lucky since I have read of a few problems with different software, Mine is a daily driver and I don't know if I can risk having her down because of software problems :(
Old Dec 18, 2001 | 02:33 AM
bparker's Avatar
bparker
Please keep in mind that they "recommend" this, and they also have a smaller diameter kit for use "with" torque management.. Give'em a call and let them advise you for the best descision.. :yesnod:
Old Dec 18, 2001 | 02:53 AM
C5 in 2002's Avatar
C5 in 2002
Thanks again,
I will call them :yesnod: :yesnod: I met with my transmission guy today and even let him drive it, He couldn't believe how soft the stock 3:15 was, he was going to make some calls, he has not put one in a C5 however the Transco is his fav :D :D
Old Dec 18, 2001 | 03:17 AM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Powerloader!!! :cool:
To TRANSCO KIT
