Vararam or halltech stinger
Old May 4, 2008 | 03:50 PM
birch64's Avatar
birch64
Default Vararam or halltech stinger
Vararam or halltech stinger which will I see better gains from on my 2000 A4 coupe?
or would it be about the same?
Old May 4, 2008 | 04:41 PM
David A's Avatar
David A
I don't have actual first had experience yet. I currently have the Stinger installed and did see some real gains after it was installed and tuned. I think 7 HP or so on the dyno. I have a Vararam waiting to be installed. I think the Vararam will out perform the Stinger simply because it is an actual Cold Air Intake system. But that is not the reason I purchased the Vararam. On my car the Stinger interferes with the hood and causes a larger gap on the front of the hood. I'm expecting the Vararam to correct this issue.
YMMV
Dave
Old May 4, 2008 | 04:51 PM
birch64's Avatar
birch64
same issue, i have the stinger now....looking to buy the vararam. now i have to find a new air bridge threw my old one out.....
Old May 4, 2008 | 05:23 PM
RogerT's Avatar
RogerT
Default Vara Ram II
I installed a Vara Ram II on my 2001 A4 a year ago. Pretty straight-forward installation with good results. Better seat-of-the-pants throttle response. The cold air intakes are at the front of he car and are pressurised at speed providing increased performance over those systems not pressurised. I am happy with the results and would do it again. I hope this helps.
Roger T
Old May 4, 2008 | 07:27 PM
EDenney's Avatar
EDenney
Definitely going to see better performance out of the Vararam, especially in actual driving conditions (no doubt on the dyno too, but more so on the road). Of course Halltech owners are going to defend them, and they're certainly an improvement over stock (anything is), but I don't think there's any question over which one is going to yield more gains. Here's a link on Vararam's website entitled "Vararam vs. the competition" which you might find interesting: http://www.vararam.com/competition.html
Just do some searching, there's a ton of info in the forums as well as the manufacturer's websites. Vararam = up to 43Hp gains on a stock C5, and .3 to .5 seconds of your 1/4 time guaranteed or they'll buy it back! You're not going to find that guarantee from any other manufactuer which says it all. Only problem is that installation is a PITA especially compared with other brands that don't siphon air in from outside the car.
Old May 4, 2008 | 07:53 PM
birch64's Avatar
birch64
Old May 4, 2008 | 11:44 PM
motogib1's Avatar
motogib1
Vararam IMHO. Outside air is cooler than air in the engine compartment so any of the available true CAI will be preferable to the filters in the engine bay. Cooler air = more available hp.
Old May 4, 2008 | 11:51 PM
nickolbag's Avatar
nickolbag
I used my Halltech air bridge with my Vararam. Had to cut it a bit but it fits perfect. Actually better than the stock bridge.
Old May 5, 2008 | 12:01 AM
nickolbag's Avatar
nickolbag
Default my take on Stinger vs Vararam
I went from a Halltech Stinger to a Vararam on a H/C car.
With the Stinger and MT DRs on Magnesium rims w/ Magnesium stock fronts I went 11.60@120 w/ a 1.60 60'.
With the Vararam and CCW drag pack I went 11.20@123 w/ a 1.51 60'.
Air was pretty close to identical. So I gained .4 with the drag pack and Vararam. Figure I gained .15 from the improved 60' and another .15 from the drag pack so that would leave .1 of a gain from the Vararam. I did pick up a consistant 3 MPH average trap as well(even though the 60's went down).
Now this is by no means "scientific" but I am confident that I did pick up a decent amount with the Vararam. If you don't own either and are looking to choose between the two I would say Vararam hands down. If you already have the Stinger I would personally stick with it unless you are looking to get every last hundreth of a second at the track.
Old May 5, 2008 | 12:26 AM
kingsey's Avatar
kingsey
Since i drive my car in the rain i just couldnt pull the trigger on the vararam. I went with the stinger and love it
Old May 5, 2008 | 01:06 AM
EDenney's Avatar
EDenney
There aren't any issues with driving a Vararam in the rain, if anyone has any doubts call the manufacturer, they stand behind their product. I wouldn't try to cross a road flooded with a foot deep of standing water, but I wouldn't do that with or without a Vararam .
Old May 5, 2008 | 03:31 PM
Dave68's Avatar
Dave68
Dyno-wise, the numbers are almost identical. Add my cold air mod to the Halltech and I'm confident that there won't be a significant difference on the road, either. The advantage of bringing cold air up from underneath is that you not only keep the intake air cool, but you also cool off the engine bay and all its electronics, rubber hoses, and plastic parts - stuff that'll cook if you run the Vararam and headers.
The cold air mod can be found here:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Even if you delete the air scoop, some cold air will still make its way up at the air filter. The difference in intake temperatures is dramatic after sitting at a stoplight and/or in stop&go traffic. I measured up to 40 degreesF differences between the Halltech/no cold air and the Halltech/cold air setups, in intake temperatures, using a "Car Chip" data logging device.
You shouldn't compare a Vararam to a Stinger; you should compare a CAI Stinger to a Vararam.
To Vararam or halltech stinger
