dash light problem
Old May 4, 2008 | 05:53 PM
gizmominou's Avatar
gizmominou
Default dash light problem
I have a 2002 z06, when i put the ignition key in the dash light come on then off but the problem is when i turn my head light on, there is no dash light... the HUD works good, this started only this spring when i took the car out of Hibernation. I have a good battery and it keeps a good charge of 14.7 volts when running can anybody help please. thanks
Old May 4, 2008 | 08:07 PM
65GGvert's Avatar
65GGvert
Turn your dash dimmer switch up.
Old May 4, 2008 | 08:49 PM
gizmominou's Avatar
gizmominou
thank you65GGvert for the info, that was the problem. I must have turned it while i was cleaning it, i feel kind of stupid but next time i will check more thorought. :o
Old May 4, 2008 | 10:41 PM
65GGvert's Avatar
65GGvert
No problem, you're not the first. In fact, the second this week if you look back through the posts.
Old May 5, 2008 | 03:01 AM
DeeGee's Avatar
DeeGee
Its called Parade Mode in the manual.
To dash light problem
