Tire sensor Glitch
Old May 5, 2008 | 12:15 AM
LATNC3's Avatar
LATNC3
Default Tire sensor Glitch
Ok, have you guys ever had one of your sensors go and show the XXX and then come back to reading tire pressure? if so, is this a precursor to something more???
Rod
Old May 5, 2008 | 12:28 AM
PaintballaXX's Avatar
PaintballaXX
If had that issue for a few months. Happens when i drive hours at a time from city to city. It always works again the next ignition cycle. Doesn't bother me to much, but id like to know whats going on. Its always the same 1.
Old May 5, 2008 | 12:36 AM
LATNC3's Avatar
LATNC3
well, it happened to me just once so far. I would also like to know
Old May 5, 2008 | 03:05 AM
DeeGee's Avatar
DeeGee
Its a precursor to the battery failing. The battery life is about 7 years or so. When the RFA fails to receive a signal for 8 secs (IIRC) it sets a DTC and gives XXX.
The problem is that if one sensor is about to fail they'll probably all go in the near future. You may wish to get the whole set changed while you're at it.
Don't forget the early C5s had a different (& more expensive) sensor that works at a different frequency. Your 98 has the old type sensors. Make sure you get the right ones for your car.
Old May 5, 2008 | 07:31 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I have one that does the same thing. You will find out that it does it more in hotter weather than when cold.
Battery is going, meaning that soon they will all go south.
Old May 5, 2008 | 01:24 PM
VETTE26yearsVETTE's Avatar
VETTE26yearsVETTE
If You Need Sensors Check With Gene, He's A Forum Vender & Is Running A Special On A Set Of 4. If You Do Have To Replace Yours Make Sure You Do A Search On Training The New Ones Before You Install Them. It's Probably Easier To Do Before They're On The Wheel.
Old May 5, 2008 | 03:30 PM
jmesox's Avatar
jmesox
I had the same problem after storing my 98 C5 all winter. I was just going to let it go until I put new tires on the car. I sure the batteries are low because of the age. After driving the car a couple of times the sensor started working fine. I’m still planing on swapping them out in the near future.
John
Old May 6, 2008 | 09:32 PM
LATNC3's Avatar
LATNC3
cool, that guys..i will keep an eye on the battery
Old May 12, 2008 | 11:17 AM
frankhamil's Avatar
frankhamil
My right rear is failing, on occasion. It seems to be related to the tire pressure, which increases as the temperature rises. When the pressure gets to about 35 psi, the sensor fails. I plan to have it checked out.
Thanks,
Frank Hamilton
Old May 12, 2008 | 11:54 AM
Bull_in_a_china_shop's Avatar
too bad we cant just disable them.....
Old May 12, 2008 | 11:59 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It is Much easier to train them before mounting in the wheels.
I did my new sensors that way in less than two minutes,and right from the driver's seat!
Old May 12, 2008 | 12:07 PM
bucwheat's Avatar
bucwheat
Mine is a 98 and still working fine.
To Tire sensor Glitch
