Rear Diff Crack
Old May 8, 2008 | 10:45 AM
Motohead1's Avatar
Motohead1
Default Rear Diff Crack
I am in the prosess of changing the trans and diff fluid in my 00 FRC. I dropped the rear cradle out just to get a good look at everything and noticed there is a inch long crack running from the front of the VSS in the cooling fin running forward. Its not leaking so its not into the actual case yet. My question is this the common area were the rears will crack? I searched and found only total carnage diffs.
I can get a pic if needed. Thanks
