Another Leaking Battery
Old Dec 17, 2001 | 01:29 AM
JC in XTC5's Avatar
JC in XTC5
Default Another Leaking Battery
Just noticed my Delco is leaking, just like mentioned many times before, under my '+'ve terminal. Enough acid leaked out to leave a small puddle so I'll have to ask them to check underneath to make sure the BCM or other electronics weren't touched. I assume they'll replace it with an AGM.
:U
Old Dec 17, 2001 | 01:32 AM
C5Cemo's Avatar
C5Cemo
Default Re: Another Leaking Battery (JC in XTC5)
They better replace it with an AGM...I'd insist it.
I hope there's no real damage, good luck!
Old Dec 17, 2001 | 01:51 AM
Pat.O's Avatar
Pat.O
I have had two Tahoes; 98 and 2000 and both have had leaking batteries at the "+" post. Wrote AC Delco. They do not care.
[Modified by Pat.O, 11:52 PM 12/16/2001]
Old Dec 17, 2001 | 08:44 AM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Re: Another Leaking Battery (Pat.O)
Seems like the cold weather brought on a number of leaking batteries in the NJ area. Although mine didn't, I did go ahead and get me a "red top." Installed it Saturday and now have peace of mind. BTW, Optima will send you a free battery cover (I chose red, may also come in yellow) upon request of their customer service dept.@800-292-4359, Ext. 469
Joe
[Modified by C54FUN, 7:11 AM 12/17/2001]
[Modified by C54FUN, 7:14 AM 12/17/2001]
Old Dec 17, 2001 | 09:23 AM
CP's Avatar
CP
Default Re: Another Leaking Battery (C54FUN)
Someone (one of the designated techies, I think.) posted that the leaking terminal is caused by an over-zealous guy over-torquing the connector.
This info I read may have been on another forum.
Old Dec 17, 2001 | 10:27 AM
wwashing's Avatar
wwashing
Default Re: Another Leaking Battery (C5Cemo)
If this battery is on your 2000, by the time they prorate it, you'd probably be just as well off just buying whatever kind of battery you want.
[Modified by wwashing, 8:28 AM 12/17/2001]
Old Dec 17, 2001 | 12:16 PM
JC in XTC5's Avatar
JC in XTC5
Default Re: Another Leaking Battery (wwashing)
Just got it replaced this morning under warrantee. The leak was continuing bad enough that I figured it couldn't wait a day or two.
They did replace it with the AGM (Delco Part #78P-7YR). When I asked them which battery they would use, they couldn't tell me whether it would be the AGM or standard Lead Acid, but it looks like the standard C5 replacement battery is now the AGM.
I asked them to also check for damage under the battery and there doesn't appear to be any. I opened up the wheel well slightly last night to check myself and it looks like the acid was dripping down along the side of the cavity.
:seeya
[Modified by JC in XTC5, 10:16 AM 12/17/2001]
To Another Leaking Battery
